12f675 A/d Miseries
Results 1 to 14 of 14
    Dec 2005
    Red face 12f675 A/d Miseries
    Hello all
    Running a 12F675 with 1 channel of a/d. Can someone take a look at this code and help me figure out why the a/d isn't running. (at least doesn't seem so) This thing is driving me crazy! I think it should run but it doesn't.
    Symptoms: My test board shows a/d in to pin as 0-5volts, but chip stays locked in "outrange" and led flashes on and off ok.
    What can I do to fix the code?
    Help will be appreciated-might save me from the rubber room!
    Ron
    Here's the code:
    @_CONFIG_INTRC_OSC_NOCLKOUT &_WDT_ON &_PWRTE_ON &_MCLRE_OFF & BODEN_OFF
    'INTERNAL OSCILLATOR (4 MHZ)
    'ENABLE WATCH DOG TIMER
    'ENABLE POWER UP TIMER
    'DISABLE MASTER CLEAR FUNCTION
    'VARIOUS OPERATION PARAMETERS
    'GPIO.0 IS A/D INPUT FROM VOLTAGE DIVIDER TO SET HIGH OR LOW
    'CHARGE. THIS FUNCTION TURNS ON 4710 MOSFET SWITCH (GPIO.4)
    'AND LED (GPIO.2) (STEADY ON) TO INDICATE FULL 3 AMP. CHARGE
    'TO BATTERY BETWEEN 12 VOLTS AND 16 VOLTS. OUTSIDE OF THESE
    'VOLTAGES, GPIO.4 IS LOW AND GPIO.2 FLASHES ON AND OFF, ONCE
    'PER SECOND. GPIO.3 IS MCLRE, PULLED TO Vcc BY 4.7K RESISTOR.
    'GPIO.0 AND GPIO.3 ARE INPUTS AND GPIO.2 AND GPIO.4
    'ARE OUTPUTS. (OTHERS COME UP AS INPUTS
    ' HARDWARE CONNECTIONS
    'GPIO.0 A/D INPUT TO ADC CHANNEL 0
    'GPIO.1 N/C
    'GPIO.2 OUTPUT TO CASE LED(flashes on and off)
    'GPIO.3 MCLR PIN
    'GPIO.4 HIGH TO PHOTOVOLTAIC MOSFET DRIVER
    'GPIO.5 N/C
    DEFINE ADC_BITS 10 '10 BIT A/D CONVERSION RESULT
    DEFINE ADC_CLOCK 3 'INTERNAL A/D RC CLOCK
    DEFINE ADC_SAMPLEUS 50 'SET SAMPLE TIME IN MICROSECONDS
    CMCON = 7 'TURN COMPARITORS OFF
    adval0 VAR WORD 'Create adval0 to store result
    TRISIO = %001001 ' Set GSIO 0 & 3 TO INPUTS
    ANSEL = %01100001 ' Set GSIO 0 TO ANALOG A/D IN W/Frc
    ' OTHER PINS TO DIGITAL
    ADCON0 = %10000001 ' Vcc REF/Turn on A/D Module
    PauseUs 50 'Wait 50 MICROSECONDS
    START:
    ADCON0.1 = 1 'Start Conversion (GO/NOT DONE BIT SET)
    WHILE ADCON0.1 = 1:WEND 'MOVE ON WHEN FINISHED WITH A/D CONVERSION
    ADCIN 0, ADVAL0 'DEFINE C0NVERSION IN VAR ADVAL0
    IF (ADVAL0 <= 906) AND (ADVAL0 >= 604) Then INRANGE
    'GO TO FULL 3 AMP RATE (MOSFET TURNED ON)
    IF (ADVAL0 <= 603) OR (ADVAL0 >= 907) Then OUTRANGE
    'GO TO TRICKLE CHARGE (MOSFET OFF-NO RESISTOR SHUNT IN)
    '10 ohm IN SERIES WITH CHARGER.
    INRANGE: 'LED ON STEADY-MOSFET TURNED ON
    High GPIO.4: High GPIO.2
    GoTo START
    OUTRANGE:'LED FLASHES ON AND OFF MOSFET OPEN
    Low GPIO.4: High GPIO.2
    Pause 500: Low GPIO.2: Pause 490: GoTo START
    Hi Ron,
    Well there are still several questions to be able to figure out what's wrong. Such as ... what is the voltage of the charging power source? What are the voltage divider resistor values. Where is the reading being taken, before or after the 10 ohm resistor. and probably a few others.
    However, there are a few things going on in the program that are suspect, but may not really be the problem.
    You seem to be trying to use both the built-in PBP ADCIN command, and manually manipulating the A/D registers. You should pick one method or the other, not both.
    In this line...
    It sets the A/D oscillator to FOSC/64, which is listed as "outside of recommended range" in the datasheet.
    It then starts a conversion, waits for it to finish, then discards the result. That is followed by an ADCIN statement that changes the oscillator to FRC, (since that was specified in the ADC_CLOCK define), and takes another reading.
    Again, this won't cause the problem you're seeing, but it's still not right.
    So maybe it's something with the questions in the first paragraph. ??
    Dec 2005
    Red face What it is!
    Hi Darrel
    The resistors are set up to provide a range of voltages somewhere between 0 and 4.75 volts to a/d for battery voltage of 0 to 20. I am still tweaking them to push it as close to 5 volts as possible. (will change the a/d numbers in the code accordingly to get as close to 12 and 16 volts as possible)
    I am not quite sure I understand your first email! Would you mind changing the code in my example to what it should be and re post it? I would really appreciate this, since this chip seems to have caused many an otherwise good code writer to "come unglued"! I do know that its Data Sheet is based on MPASM and Microchip's language; but I have tried for 10 years, and cannot make sense of that jibberish, anyway!!
    Thanks again!
    Ron
    Well, here's what I think you should have...
    @  __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BODEN_OFF
                    'GPIO.1 N/C
                    'GPIO.3 MCLR PIN
                    'GPIO.5 N/C
    DEFINE OSC          4
    TRISIO = %001001        ' Set GSIO 0 & 3 TO INPUTS, others to OUTPUT
    ANSEL = %00110001 	    ' Set GSIO 0 TO ANALOG A/D IN W/Frc
    ADCON0.7 = 1	        ' Right Justify for 10-bit
    START:
        ADCIN 0, ADVAL0         ' Read A/D channel 0
        IF (ADVAL0 <= 906) AND (ADVAL0 >= 604) Then   ; INRANGE
            High GPIO.4   'GO TO FULL 3 AMP RATE (MOSFET TURNED ON)
            High GPIO.2
        else                                          ; OUTRANGE
            Low GPIO.4   'GO TO TRICKLE CHARGE (MOSFET OFF-NO RESISTOR SHUNT IN)
            High GPIO.2  '10 ohm IN SERIES WITH CHARGER.
            Pause 500
            Low GPIO.2
            Pause 490
    GoTo START
    Also, there were some problem's with the CONFIG line. You can't see it in the post because it's all scruched up to the left. But, when you "Quote" post #1 you can see that there's no space between the @ and __CONFIG, and there's only 1 underscore before the CONFIG. There should be 2.
    Added: And there should be a space between __CONFIG and the first parameter _INTRC_OSC_NOCLKOUT.
    HTH,
    Dec 2005
    Thumbs up Thanks Darrel!
    Darrel,
    The code you modified is working perfectly! Thanks very much! I was about to enter the proverbial "rubber room" over this one. I hope these examples will be helpful to others on the forum who have been messed over by the 12F675.
    By the way, have a happy new year!
    Ron
    That's right. Bounce it off of us, before bouncing off the walls.
    Ha Ha, Happy New Year to you too!
  1. How do I use 10 bit A/D on 8 bit Pic? 12F675
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 1st April 2020, 20:10
  2. Need help with LM34 and 12F675
    Last Post: - 6th December 2009, 13:06
  3. 12F675 A/D and GPIO sleep interrupt
    By macinug in forum mel PIC BASIC Pro
    Last Post: - 8th September 2008, 14:39
  4. Need advice on A/D
    By james in forum mel PIC BASIC Pro
    Last Post: - 24th August 2007, 19:30
  5. A/D converter fails?
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 13th February 2006, 18:57
