EasyHid and 18F2550 - why? what? how?
Results 1 to 1 of 1
    Aug 2005
    Default EasyHid and 18F2550 - why? what? how?
    I have a 18F2550 talking to windows with no apparent problems [see attached screendump].
    Easyhid generated the code, and I made what I believed to be the relevant changes [minor ones at first, in order to test all is well].
    Sure enough, if I connect the cable, the 'OnPlugged' event fires and the textbox changes to 'Plugged In..." [see code below].
    However, no matter what I do, I cannot get the 'hidRead' event to fire, nor does the 'OnUnplugged' event ever fire, when I disconnect the cable.
    I have scoured these forums and the 'net in general, and cannot see what I am missing...
    I've included the code snippets below. Any help would not only be much appreciated, but would save me from ritual hari-kari... ;-)
    Giulio
    ' a HID device has been plugged in...
    Public Sub OnPlugged(ByVal pHandle As Long)
    If hidGetVendorID(pHandle) = VendorID And hidGetProductID(pHandle) = ProductID Then
    ' ** YOUR CODE HERE **
    Text1.Text = "Plugged In..."
    End If
    End Sub
    ' a HID device has been unplugged...
    Public Sub OnUnplugged(ByVal pHandle As Long)
    Text1.Text = "Unplugged..."
    End If
    End Sub
    ' on read event...
    Public Sub OnRead(ByVal pHandle As Long)
    ' read the data (don't forget, pass the whole array)...
    If hidRead(pHandle, BufferIn(0)) Then
    Text1.Text = Val(BufferIn(0))
    ' first byte is the report ID, e.g. BufferIn(0)
    ' the other bytes are the data from the microcontrolller...
    End If
    End Sub
    pic code
    DEFINE OSC 20
    USBBufferSizeMax con 8 ' maximum buffer size
    USBBufferSizeTX con 8 ' input
    USBBufferSizeRX con 8 ' output
    ' the USB buffer...
    USBBuffer Var Byte[USBBufferSizeMax]
    USBBufferCount Var Byte
    ' * main program loop - remember, you must keep the USB *
    ' * connection alive with a call to USBService every couple *
    ' * of milliseconds or so... *
    usbinit
    ProgramStart:
    ' gosub DoUSBIn
    USBBuffer[0] = 79
    USBBuffer[1] = 75
    gosub DoUSBOut
    goto ProgramStart
    ' * receive data from the USB bus *
    DoUSBIn:
    USBBufferCount = USBBufferSizeRX ' RX buffer size
    USBService ' keep connection alive
    USBIn 1, USBBuffer, USBBufferCount, DoUSBIn ' read data, if available
    ' * wait for USB interface to attach *
    DoUSBOut:
    USBBufferCount = USBBufferSizeTX ' TX buffer size
    USBOut 1, USBBuffer, USBBufferCount, DoUSBOut ' if bus available, transmit data
  1. Vusb capacitor for USB comms with 18f2550
    By rjones2102 in forum mel PIC BASIC Pro
    Last Post: - 25th September 2008, 00:15
  2. Problem to connect with 18F2550
    By Kacto in forum mel PIC BASIC Pro
    Last Post: - 11th January 2008, 20:56
  3. EasyHID max usb buffer size
    By jizyjuice in forum USB
    Last Post: - 29th November 2007, 06:12
  4. 18f2550 'access is denied' USB error?
    By Giulio in forum mel PIC BASIC Pro
    Last Post: - 30th December 2006, 15:29
  5. HIDMakerFS versus EasyHID
    By Demon in forum USB
    Last Post: - 15th August 2006, 09:01
