ascii conversion help needed
Results 1 to 13 of 13
    Jun 2005
    Up the bush, Western Plains, NSW Au
    Hmmmm...
    Sort it as it comes in, rather than once it is in..makes sense. I'll give it a try.
    After having slept on it, If I use the known location as the user number, as long as a card reading matches what's in the EEPROM then I can use the location as the ID number. It doesn't really matter what's in there, as long as it is a match.
    Thanks heaps Darrel,
    PM
    Sure, as long as everyone has the same security level. But if there are restrictions like giving access to certain people at certain times of the day, then you'll need to know who they are.
    I'm sure you could do this on your own, but here's a possible search routine. Might save you some time. Haven't thoroughly tested it, but it should be close.
    <font color="#000000"><b>Record </b><font color="#008000"><b>VAR BYTE     </b></font><font color="#0000FF"><b><i>; Start of each Record
    </i></b></font><b>Ptr    </b><font color="#008000"><b>VAR BYTE     </b></font><font color="#0000FF"><b><i>; Points to each byte in the record
    </i></b></font><b>TempB  </b><font color="#008000"><b>VAR BYTE     </b></font><font color="#0000FF"><b><i>; Temp var
    </i></b></font><b>MaxEE  </b><font color="#008000"><b>CON </b></font><b>250      </b><font color="#0000FF"><b><i>; Start addr of Last available record
    </i></b></font><b>SerNum </b><font color="#008000"><b>VAR BYTE</b></font>[<b>5</b>]  <font color="#0000FF"><b><i>; The S/N to search for
    </i></b></font><b>UserID </b><font color="#008000"><b>VAR BYTE     </b></font><font color="#0000FF"><b><i>; Resulting User ID
    </i></b></font><b>SearchUser</b>:
        <font color="#008000"><b>FOR </b></font><b>Record </b>= <b>0 </b><font color="#008000"><b>TO </b></font><b>MaxEE </b><font color="#008000"><b>STEP </b></font><b>5
            </b><font color="#008000"><b>FOR </b></font><b>Ptr </b>= <b>0 </b><font color="#008000"><b>TO </b></font><b>4
                </b><font color="#008000"><b>READ </b></font><b>Record </b>+ <b>Ptr</b>, <b>TempB
                </b><font color="#008000"><b>IF </b></font><b>SerNum</b>(<b>Ptr</b>) &lt;&gt; <b>TempB </b><font color="#008000"><b>THEN </b></font><b>RecNotMatch
            </b><font color="#008000"><b>NEXT </b></font><b>Ptr
            </b><font color="#008000"><b>GOTO </b></font><b>MatchFound
     RecNotMatch</b>:
        <font color="#008000"><b>NEXT </b></font><b>Record
        UserID </b>= <b>0    </b><font color="#0000FF"><b><i>; returns 0 if no match found
        </i></b></font><font color="#008000"><b>RETURN
     </b></font><b>MatchFound</b>:
        <b>UserID </b>= <b>Record </b>/ <b>5 </b>+ <b>1 </b><font color="#0000FF"><b><i>; returns UserID starting at 1
    </b></font>
    Jun 2005
    G'day Darrel,
    The things you suggested about sorting worked a treat.
    I'm not really interested in 'all the bells and whistles' as far as time zones, access levels etc. as that is already being done by the dozen by everyone else.
    I got a project for just a simple 'valid card = access' type thing, which is pretty hard to find out there.
    Apart from that all the discussion with you has been great. It sure helps to have someone and an excellent forum, to bounce things around in.
    I had the matching already done with the 16 byte data that I had and just gotta change that to 8 byte version.
    I'll be back (probably) when I'm stuck for something else. (probably)
    Thanks again.
    PM
    Ummm, Why 8 bytes?
    If the idea was to store more users in the limited EEPROM space, and you don't need to have other security settings per user. Why not have a 5 byte record size? That's a 60% increase in users. 51 vs 32. (assuming 256 EEPROM)
    Jun 2005
    Hi again Darrel,
    All that stuff worked a treat. Thanks.
    Now there is a follow up to that series.
    Now that I am getting 5 bytes to play with, I am simply generating a 4 digit decimal code by taking the last numeral from each of the bytes (decimalised) ((along the lines of dec1 card(1) dec1 card(2) dec1 card(3) dec1 card(4)))
    This works fine, as long as I am sending these numerals out serially or sending to an LCD. What I am having trouble with is sending the bottom half of the decimal byte to a port. The byte should be %0000xxxx where xxxx is the decimal 0 - 9 in binary. Right so far??
    It seems to me that I can't qualify the byte as dec1, BIN4 or anything like that when I am not sending it to the port. I have tried portb = var AND %00001111 which to my way of thinking should mask off the top nibble but what I get out of the port is a full byte of 1's with no resemblance to the numeral that can be deciphered at all.
    I got a few other things to try, so I'll be back.
    I'll have a look at BCD and see if I can make that work.
    What you need is the Bitwise operators "&" + "|" (OR).
    Since you only want to output the lower bits of PORTB, you have to read PORTB first, mask out the lower bits, then OR the new bits in.
    portb = (portb & %11110000) | (var & %00001111)
    Jun 2005
    Hi Darrel,
    I've been up all nite trying to sort this thing out. Let's see if I can explain where I am ATM:
    I've got 5 bytes coming in as 5 hex2 numbers.
    I am taking the low nibble of each of those as hex1 numerals.
    Gotta then convert then to dec1 digits and write them to port b low nibble.
    I think I've got it sorted...
    I don't think I will need to read, mask, or, then write portb as there is a set sequence that needs following, but that will be another problem, probably.
    I just gotta write the low nibble with the high nibble all 0's and then do some bit manipulation with the high nibble. Should be pretty easy.
    Famous last words huh?
  1. ASCII to Long conversion
    By TerdRatchett in forum mel PIC BASIC Pro
    Last Post: - 6th March 2009, 00:43
  2. A/D conversion problem in 18F2520, 2523, 2550 etc.
    By selimkara in forum mel PIC BASIC Pro
    Last Post: - 10th March 2008, 17:26
  3. SerIn2 ASCII Conversion
    By rwskinner in forum mel PIC BASIC Pro
    Last Post: - 4th March 2008, 22:41
  4. ASCII Viewer Needed
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 19th January 2008, 06:29
  5. Conversion of 10-bit word into ASCII
    By Barry Johnson in forum mel PIC BASIC Pro
    Last Post: - 16th January 2005, 15:26
