ISD4003 & 16F877 Interface
Results 1 to 6 of 6
Threaded View
    Jan 2006
    Istanbul
    Default ISD4003 & 16F877 Interface
    I have this code from melabs.
    Referring to this code, can someone please complete the schematic for the correct connection between these two chips, ISD4003 and F877?
    ' PicBasic Pro 2.42 or later, LAB-XT Experimenter Board, PIC16F877-20
    ' Program to record and play multiple voice messages.
    ' Uses hardware SPI for 2-way communication to the voice device.
    ' Record messages in sequence by pressing the A key, speaking into
    ' a headset mic, then pressing the B key to stop recording.  The first
    ' message may be played back by pressing 0, the second by pressing 1, etc.
    ' EPIC Programmer should not be connected to the ICSP header
    ' when running this code.  It may interfere with the operation
    ' of the keypad.
    DEFINE LOADER_USED	1				' Only required for melabs Loader
    DEFINE OSC 20						' Define for 20MHz crystal on LAB-XT
    DEFINE  LCD_DREG        PORTD
    DEFINE  LCD_DBIT        4
    DEFINE  LCD_RSREG       PORTE
    DEFINE  LCD_RSBIT       0
    DEFINE  LCD_EREG        PORTE
    DEFINE  LCD_EBIT        1
    select_voice	VAR	PORTD.2			' Chip select for voice recorder
    serial_mcu_out	VAR	PORTC.5			' SPI data output
    serial_clk		VAR	PORTC.3			' SPI clock pin
    voice_int		VAR	PORTA.5			' Interrupt signal from voice device
    ADCON1 = 7      ' Set PORTA and PORTE to digital
    Pause 200       ' Wait for LCD to start up
    LCDOut $fe,1	' Clear display
    ' Define program variables
    col     		VAR BYTE            ' Keypad column
    row     		VAR BYTE            ' Keypad row
    key     		VAR BYTE            ' Key value
    control			VAR	BYTE
    address			VAR	WORD
    isd_data_in		VAR	WORD
    isd_data_out	VAR	WORD
    message_loc		VAR WORD[16]
    i				VAR	BYTE
    i = 0
    message_loc[0]=0
    High select_voice
    ' set up SPI port
    BF	VAR	SSPSTAT.0		' Alias Buffer Full flag
    SSPSTAT = %01000000		' Set SMP=0, CKE=1
    SSPCON  = %00100010		' Set CKP=0, SPI master, clock = Fosc/64, Enable the port
    TRISC   = %00010100		' Set data-direction to allow SPI on PortC
    OPTION_REG.7 = 0        ' Enable PORTB pullups
    initialize:
    	LCDOut $fe, 1,  "A to record"	' Display intitial prompt
    	LCDOut $fe,$C0, "B to stop"
    loop:
    	'IF (isd_on = 1) AND (voice_int = 0) Then GoSub finish
    	GoSub getkey			' Get a key from the keypad
    	Select Case key			' Take action based on key
    		Case 12				' "A" key starts recording
    			LCDOut $fe,1, "recording message: ",DEC i		' Display
    			LCDOut $fe,$c0, "address: ",HEX message_loc[i]	' Display
    			address = message_loc[i]	' Set address to begin recording
    			GoSub record				' send record command to voice chip
    		Case 13				' "B" key stops recording
    			LCDOut $fe,1, "stop"		' Display
    			GoSub finish	' Send stop command and receive end address
    			i = (i + 1) & $0F		' Increment message counter, loop 0 to 15
    			message_loc[i] = (isd_data_in >> 2) + 2	' Remove status bits from end address, add 2 for separation
    		Case Is < 10		' Number keys play the corresponding message
    			LCDOut $fe,1, "playing message: ",DEC key			' Display
    			LCDOut $fe,$c0, "address: ", HEX message_loc[key]	' Display
    			address = message_loc[key]	' Set playback address
    			GoSub ply		' Send play command
    wait_for_int:
    			IF voice_int = 1 Then wait_for_int	' Loop here until end of message
    			GoSub finish	' Power down the voice chip
    			GoTo initialize	' Reinitialize the display
    	End Select
    GoTo loop               ' Do it forever
    ' Subroutine to get a key from keypad
    getkey:
    	' Check for keypress
    	For row = 0 TO 3        ' Loop for 4 rows in keypad
            PORTB = 0       	' All output pins low
            TRISB = ~(DCD row)  ' Set one row pin to output
            '@ NOP				' Fudge for 18F452
            col = PORTB >> 4	' Read column pins
            IF col != $0F Then	' Check if key is pressed
            	HPwm 1,127,7500	' Begin speaker tick
            	GoTo gotkey 	' If any keydown, exit loop and handle it.
            EndIF
    	Next row				' Repeat for the next row
    	key = $FF				' No keys down, set key to $FF
    	Return          		' Return to main loop
    gotkey: 					' Change row and column to key number 0 - 15
    	Pause 15                ' Debounce
    	HPwm 1,0,0				' End speaker tick
    	' Wait for all keys up
    	TRISB = $F0             ' Least significant 4 pins out, top 4 pins in
    	IF ((PORTB >> 4) != $0F) Then gotkey	' If any keys down, loop
    	key = (row * 4) + (NCD (col^$0F)) - 1	' Combine row and column into numeric value
    	' Translate key to display label:
    	' 1  2  3  A
    	' 4  5  6  B
    	' 7  8  9  C
    	' *  0  #  D
    	'LookUp key,["123A456B789C*0#D"],disp_key
    	' Translate key to DTMFOUT tone
    	' 1   2   3   12
    	' 4   5   6   13
    	' 7   8   9   14
    	' 10  0   11  15
    	LookUp key,[1,2,3,12,4,5,6,13,7,8,9,14,10,0,11,15],key
    ' ISD4003 Control Values:
    power_up	CON	%00100000	' Power up the device
    set_play	CON %11100000	' Set the playback address
    play		CON %11110000	' Start playback
    set_rec		CON %10100000	' Set the record address
    rec			CON	%10110000	' Start recording
    power_dwn	CON %00010000	' Stop playback or record and power down the device
    record:		'Record a message
    		control = power_up	' Set control byte to power up
    		GoSub spi_send		' Send to device
    		Pause 100			' Pause to let the device come up
    		control = set_rec	' Set control byte to set record address
    ply:
    		Pause 50			' Pause to let the device come up
    		control = set_play	' Set control byte to set play address
    finish:
    		control = power_dwn	' Set control byte to power down
    spi_send:		' Use hardware SPI port to send and receive simultaneously
    		Low select_voice	' Select voice chip
    		address.highbyte = (address.highbyte & %00000111) | control ' Combine address and control data
    		isd_data_out = address REV 16 	' Reverse the bits for LSB first
    		SSPBUF = isd_data_out.highbyte	' Write the first byte to SSPBUF to initiate trasfer
    		GoSub spi_wait					' Wait for transfer to finish
    		isd_data_in.highbyte = SSPBUF	' Read the incoming data from SSPBUF
    		SSPBUF = isd_data_out.lowbyte	' Write the second byte to SSPBUF to initiate transfer
    		isd_data_in.lowbyte = SSPBUF	' Read the incoming data from SSPBUF
    		isd_data_in = isd_data_in REV 16	' Reverse the bits of incoming data (received LSB first)
    		High select_voice 	' Deselect voice chip
    spi_wait:					' Wait for transfer to finish
    		IF BF = 0 Then spi_wait		' If the flag is still zero, keep waiting
    		BF = 0				' Reset the flag
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1288&stc=1&d=116706621 8 " >
  1. LCDOUT w/custom interface?
    By Mike, K8LH in forum PBP Extensions
    Last Post: - 3rd March 2015, 04:54
  2. Replies: 33
    Last Post: - 19th March 2010, 04:02
  3. 16f877 and ps/2 keyboard error???
    By boraciner in forum mel PIC BASIC Pro
    Last Post: - 5th July 2009, 09:14
  4. 'SCI' interface
    By ecua64 in forum Off Topic
    Last Post: - 29th September 2005, 17:02
  5. User Configuration Interface in PBP
    By Radiance in forum mel PIC BASIC Pro
    Last Post: - 7th February 2004, 09:00
