Interrupt while asmmbler command.
Results 1 to 3 of 3
    May 2006
    Default Interrupt while asmmbler command.
    I know that PBP will not go to ISR while it is in a PBP command, but is it also true when performing a asm command ?
    I tryed it and as i show it dosn't ,am i wrong ?
    Shamir
    Feb 2005
    Kolkata-India
    Default What is your app ?
    PBP does not branch to the interrupt vector when an interrupt occurs. By using the On Interrupt, PBP checks for interrupts and flags it. When it finishes the current function it jumps to the defined basic interrupt routine. For example when executing a function block, say serout, PBP would complete the serial out and then process the interrupt. So that's where the latancy is introduce. If PBP is executing a pause then it does it by some iterations of its own library. That means pause is itself a delay loop and your statement defines how many times it should loop around to introduce the desired delay. Thus while executing its own library PBP would finish it and then process. If you are executing an asm statement that already means that PBP is not in the process of executing its built in library. So the latency is less.
    As I always mention please look at this thread and appreciate the smart and hard work darrel has done, http://www.picbasic.co.uk/forum/showthread.php?t=3251
    BTW if your app is time sensitive and you would be handling higher/lower priority interrupts it is a good idea to use asm. Also to reduce your bank addressing headache you can use the system bank to hold your variables (if they fit) used in the ISR. If not then indirect addressing is what I use on the PIC18
    Happy New Year to All
    Sougata
    Hi,Shamir
    Answering your question, Assembler interrupts have a small latence time ... Microchips tells "around" 4 clock cycles in its datasheets and midrange manual.
    this gives one assembler instruction time ... two, if pessimistic !!!
    Now, the good question is to know EXACTLY what needs to be saved ( and restored after ... ) THIS portion of code always take some time, and even need some timing values to be corrected in a further step.
    Darrel's "instant Interrupts" is the easiest way to care with interrupts "headache" ... but just takes MINIMUM time - Only MINIMUM !!!
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  2. Can't ID interrupt source with this IntHandler??
  3. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 19:14
  4. LCDout Command causes Interrupt!!??
    Last Post: - 31st March 2005, 05:18
