Hi paul borgmeier
Thank for you reply..
Soory! for circuit not clear for you.. , we used 7 seg COM Cathode..
This circuit i have test with time counter alredly done no problem.
But after we apply Display sub to 1820 reading ,so got problem display cannot show reading on 7 seg display..
Pls any xepert advise >> very confiuse for me
code: time conter
DEFINE LOADER_USED 1
@ Device pic16F877, xt_OSC, BOD_OFF, PWRT_ON, WDT_OFF, PROTECT_OFF,WRT_ON
Segments Var PORTC
Digits Var PORTD
i Var Byte
n Var Byte
J var byte
Value Var WORD
Hr var byte
Minute var BYTE ' Define minute variable
Second var BYTE ' Define second variable
Ticks var byte ' Define pieces of seconds variable
D_up var byte
clear ' clear all RAM (sets all VAR declarations to zero)
TRISc = $00 ' Set segment pins to output
TRISd = $f0 ' Set digit pins to output
TrisB = $00
Portb = $00
OPTION_REG = $55 ' Set TMR0 configuration 1:64
INTCON = $A0 ' Enable TMR0 interrupts
On Interrupt Goto int0
mainloop:
goto display
goTo mainloop ' Do it forever
disable
int0:
Ticks = Ticks + 1 ' Count pieces of seconds
If Ticks < 61 Then goto ExitInterrupt ' 61 ticks per second
' One second elasped - update time
Ticks = 0
Second = Second + 1
If Second >= 60 Then
Second = 0
Minute = Minute + 1
If Minute >= 60 Then
D_up =1
Minute = 0
Hr =hr + 1
If Hr >= 60 Then
Hr = 0
Endif
goto mainloop
display:
If D_up = 1 then
VALUE = ((Hr*100)+Minute)
goto dup
VALUE = ((minute*100)+second)
dup:
For i = 0 To 3 ' Loop through 4 digits
n = Value Dig i ' Get digit to display
' Gosub display1 ' Display the value
Digits = $ff
Lookup n, [$3F, $06, $5B, $4F, $66, $6D, $7D, $07, $7F, $6F,_
$77, $7C, $39, $5E, $79, $71, $0FF], Segments
Digits = ~Dcd i
NEXT I
goto mainloop
ExitInterrupt:
INTCON.2 = 0 'clear the interrupt flag
Resume
enable
code : 1820 reading
Define LOADER_USED 1
Segments Var PORTC
Digits Var PORTD
i Var Byte
n Var Byte
Value Var Word
' Allocate variables
command var byte ' Storage for command
J var byte ' Storage for loop counter
temp var word ' Storage for temperature
DQ var PORTd.4 ' Alias DS1820 data pin
DQ_DIR var TRISd.4 ' Alias DS1820 data direction pin
TrisB = $00
Portb = $00
On Interrupt Goto display
ADCON1 = 7 ' Set PORTA and PORTE to digital
'debug ====
DEFINE HSER_RCSTA 90h
DEFINE HSER_TXSTA 24h
DEFINE HSER_SPBRG 12 ' 19200 Bauds ,4 m
'debug ====
' Mainloop to read the temperature and display on LCD
mainloop:
Gosub init1820 ' Init the DS1820
command = $cc ' Issue Skip ROM command
Gosub write1820
command = $44 ' Start temperature conversion
Gosub write1820
Pause 2000 ' Wait 2 seconds for conversion to complete
Gosub init1820 ' Do another init
Gosub write1820
command = $be ' Read the temperature
Gosub write1820
Gosub read1820
'Display the decimal temperature
HSEROUT ["Temp = ",dec (temp>>1),".", dec (temp.0*5)," C",13,10]
Goto mainloop ' Do it forever
' Initialize DS1820 and check for presence
init1820:
Low DQ ' Set the data pin low to init
Pauseus 500 ' Wait > 480us
DQ_DIR = 1 ' Release data pin (set to input for high)
Pauseus 100 ' Wait > 60us
If DQ = 1 Then
'Lcdout $fe, 1, "DS1820 not present"
Pause 500
Goto mainloop ' Try again
Endif
Pauseus 400 ' Wait for end of presence pulse
' Write "command" byte to the DS1820
write1820:
For j = 1 to 8 ' 8 bits to a byte
If command.0 = 0 Then
Gosub write0 ' Write a 0 bit
Else
Gosub write1 ' Write a 1 bit
Endif
command = command >> 1 ' Shift to next bit
Next j
' Write a 0 bit to the DS1820
write0:
Low DQ
Pauseus 60 ' Low for > 60us for 0
' Write a 1 bit to the DS1820
write1:
Low DQ ' Low for < 15us for 1
@ nop ' Delay 1us at 4MHz
Pauseus 60 ' Use up rest of time slot
' Read temperature from the DS1820
read1820:
For J = 1 to 16 ' 16 bits to a word
temp = temp >> 1 ' Shift down bits
Gosub readbit ' Get the bit to the top of temp
Next J
' Read a bit from the DS1820
readbit:
temp.15 = 1 ' Preset read bit to 1
Low DQ ' Start the time slot
If DQ = 0 Then
temp.15 = 0 ' Set bit to 0
Endif
Pauseus 60 ' Wait out rest of time slot
'================== 7 seg ment display ==============================
disable
display:
VALUE = (temp >>1)
Digits = $ff
Digits = ~Dcd i
NEXT I
goto mainloop
Resume
enable
Anyone is welcome to contribute and chime in.
