Sayzer,
You have it correct for Common Anode in post #10 (at least the first three are correct - I didn't check your others). The OP should be grateful for your help because you probably saved him hours of work and frustration)
Best Wishes
Sayzer,
Best Wishes
Paul Borgmeier
Salt Lake City, UT
USA
__________________
Paul,
Ok, here is the clarification.
(from 0 to 9)
Common Anode : $c0, $F9, $A4, $B0, $99, $92, $82, $F8, $80, $90
Common Cathode : $3F, $06, $5B, $4F, $66, $6D, $7D, $07, $7F, $6F
Using Dot or not changes from set to set.
These are what I use.
Hi paul borgmeier
I'm not understand for item 1
1) On your buffer, tie 1 and 19 low so they do not float.
For item 4 , as you advise with modify some hard were right, Do you have other way with out modify hard or not.
1) On U2, pins 1 and 19 both must be connected to GND (or held low) in order for the input to be placed on the output of the buffer. If either pin is high, then the entire output of U2 will be tri-stated (high impedance). Floating means leaving pins NOT or unconnected, which is not good because they can "do what they want" - stay low, drift high, or worse go somewhere in-between. Just connect both 1 and 19 to GND and you will be set.
4) The DP can be set entirely in software using the added line of code OR it can be set in hardware. If you cannot change your circuit, then use the software version. Just add the IF-THEN statement shown in 4) and you should have a DP turned on.
Paul Borgmeier
Salt Lake City, UT
USA
__________________
Hi paul borgmeier
Thank for you reply..
Soory! for circuit not clear for you.. , we used 7 seg COM Cathode..
This circuit i have test with time counter alredly done no problem.
But after we apply Display sub to 1820 reading ,so got problem display cannot show reading on 7 seg display..
Pls any xepert advise >> very confiuse for me
code: time conter
DEFINE LOADER_USED 1
@ Device pic16F877, xt_OSC, BOD_OFF, PWRT_ON, WDT_OFF, PROTECT_OFF,WRT_ON
Segments Var PORTC
Digits Var PORTD
i Var Byte
n Var Byte
J var byte
Value Var WORD
Hr var byte
Minute var BYTE ' Define minute variable
Second var BYTE ' Define second variable
Ticks var byte ' Define pieces of seconds variable
D_up var byte
clear ' clear all RAM (sets all VAR declarations to zero)
TRISc = $00 ' Set segment pins to output
TRISd = $f0 ' Set digit pins to output
TrisB = $00
Portb = $00
OPTION_REG = $55 ' Set TMR0 configuration 1:64
INTCON = $A0 ' Enable TMR0 interrupts
On Interrupt Goto int0
mainloop:
goto display
goTo mainloop ' Do it forever
disable
int0:
Ticks = Ticks + 1 ' Count pieces of seconds
If Ticks < 61 Then goto ExitInterrupt ' 61 ticks per second
' One second elasped - update time
Ticks = 0
Second = Second + 1
If Second >= 60 Then
Second = 0
Minute = Minute + 1
If Minute >= 60 Then
D_up =1
Minute = 0
Hr =hr + 1
If Hr >= 60 Then
Hr = 0
Endif
goto mainloop
display:
If D_up = 1 then
VALUE = ((Hr*100)+Minute)
goto dup
VALUE = ((minute*100)+second)
dup:
For i = 0 To 3 ' Loop through 4 digits
n = Value Dig i ' Get digit to display
' Gosub display1 ' Display the value
Digits = $ff
Lookup n, [$3F, $06, $5B, $4F, $66, $6D, $7D, $07, $7F, $6F,_
$77, $7C, $39, $5E, $79, $71, $0FF], Segments
Digits = ~Dcd i
NEXT I
goto mainloop
ExitInterrupt:
INTCON.2 = 0 'clear the interrupt flag
Resume
enable
code : 1820 reading
Define LOADER_USED 1
Segments Var PORTC
Digits Var PORTD
i Var Byte
n Var Byte
Value Var Word
' Allocate variables
command var byte ' Storage for command
J var byte ' Storage for loop counter
temp var word ' Storage for temperature
DQ var PORTd.4 ' Alias DS1820 data pin
DQ_DIR var TRISd.4 ' Alias DS1820 data direction pin
TrisB = $00
Portb = $00
On Interrupt Goto display
ADCON1 = 7 ' Set PORTA and PORTE to digital
'debug ====
DEFINE HSER_RCSTA 90h
DEFINE HSER_TXSTA 24h
DEFINE HSER_SPBRG 12 ' 19200 Bauds ,4 m
'debug ====
' Mainloop to read the temperature and display on LCD
mainloop:
Gosub init1820 ' Init the DS1820
command = $cc ' Issue Skip ROM command
Gosub write1820
command = $44 ' Start temperature conversion
Gosub write1820
Pause 2000 ' Wait 2 seconds for conversion to complete
Gosub init1820 ' Do another init
Gosub write1820
command = $be ' Read the temperature
Gosub write1820
Gosub read1820
'Display the decimal temperature
HSEROUT ["Temp = ",dec (temp>>1),".", dec (temp.0*5)," C",13,10]
Goto mainloop ' Do it forever
' Initialize DS1820 and check for presence
init1820:
Low DQ ' Set the data pin low to init
Pauseus 500 ' Wait > 480us
DQ_DIR = 1 ' Release data pin (set to input for high)
Pauseus 100 ' Wait > 60us
If DQ = 1 Then
'Lcdout $fe, 1, "DS1820 not present"
Pause 500
Goto mainloop ' Try again
Endif
Pauseus 400 ' Wait for end of presence pulse
' Write "command" byte to the DS1820
write1820:
For j = 1 to 8 ' 8 bits to a byte
If command.0 = 0 Then
Gosub write0 ' Write a 0 bit
Else
Gosub write1 ' Write a 1 bit
Endif
command = command >> 1 ' Shift to next bit
Next j
' Write a 0 bit to the DS1820
write0:
Low DQ
Pauseus 60 ' Low for > 60us for 0
' Write a 1 bit to the DS1820
write1:
Low DQ ' Low for < 15us for 1
@ nop ' Delay 1us at 4MHz
Pauseus 60 ' Use up rest of time slot
' Read temperature from the DS1820
read1820:
For J = 1 to 16 ' 16 bits to a word
temp = temp >> 1 ' Shift down bits
Gosub readbit ' Get the bit to the top of temp
Next J
' Read a bit from the DS1820
readbit:
temp.15 = 1 ' Preset read bit to 1
Low DQ ' Start the time slot
If DQ = 0 Then
temp.15 = 0 ' Set bit to 0
Endif
Pauseus 60 ' Wait out rest of time slot
'================== 7 seg ment display ==============================
disable
display:
VALUE = (temp >>1)
Digits = $ff
Digits = ~Dcd i
NEXT I
goto mainloop
Resume
enable
Chai98a,
It is clear to me as presented. Is it wrong? I did not assume Common Anode – you told me it was Common Anode (see your third post). The transistors shown in your schematic and the code line Digits=~DCD i also imply Common Anode.Soory! for circuit not clear for you.. , we used 7 seg COM Cathode..
Your code is largely not commented
Your schematic is not complete
I spent considerable time sorting all this out and now I will not offer more until you give more detail.
1) Is the the schematic fragment correct?
2)What is the P/N of Q1-Q4 are they really PNP?
3)What troubles are you having (i.e., does the display light up (at all)? wrong temp? junk? just missing DP?)
4) Are pins 1 and 19 tied low on U2?
5) With the code you posted in #17, how does temp get set? (I don't believe it ever does)
From post #7and from post #17I can read data temp from ds1820 and send to RS232 -->OK but canot to diplay to 7 Seg. Ex 29.5C
it appears to me you have everything you need – your circuit works and you must have code to drive it; your temperature sensor reads temperature correctly.This circuit i have test with time counter alredly done no problem
I am not sure how to help you until you provide more information
Paul Borgmeier
Salt Lake City, UT
USA
__________________
Paul, let me help you here a little.
I see you are trying to help; all of us went through the same process that Chai98a is now going through.
I am sure when Chai98a gets more experienced, he will also help others on this forum as much as he can.
Chai98a, are you using standard 4x7 segments LED display? or it is one of those LARGE ones?
Also, why are you using 74HC ?
Based on your answer, I will post a schematic for you.
With this talk of CC and CA displays, I'd like to share a technique I've used and found very useful.
I like to design PCBs that would work with CA as well as CC displays; the only hardware difference between the two is whether to tie the emitters of the driver transistors to +5 or ground, depending on the display.
So, provide for a jumper that lets you select between the two.
AND, use this signal as an input to the PIC to tell it what kind of display is being used. Keep 2 lookup tables in the code, one for CA and the other for CC; depending on the state of the jumpered signal, the code uses the corresponding lookup.
During production time, then, it becomes easier as one could use either CA or CC, without having to change the code; just connect the common line to +5 or Gnd, and it will work.
Anand
