How to display dot on 7-seg , 4 digit
Results 1 to 28 of 28
    Think of the display as a 8 segment display, where the eighth 'segment' is the decimal. Keep this 'segment' off in all the digits, except for the one where you want the decimal to show.
    Anand
    May 2005
    Need more informatiom
    here is may code :for display 7-seg
    For i = 0 To 3 ' Loop through 4 digits
    n = Value Dig i ' Get digit to display
    Gosub display1 ' Display the value
    NEXT I
    goto mainloop
    display1:
    Digits = $ff ' All digits off to prevent ghosting
    ' Convert binary number in n to segments for LED
    ' COM ANODE 1234567890
    Lookup n, [$3F,$06, $5B, $4F, $66, $6D, $7D, $07, $7F, $6F], Segments
    ' Set digit pin i to 0 (on) and the rest of the pins to 1 (off)
    Digits = ~Dcd i
    Feb 2003
    Salt Lake City, Utah USA
    Question
    Your code is not complete! You have a nice lookup table but you do not use the outcome from the table? Where do you use the variable Segments? Is Digits the name of your port? (which you imply when you set it = $FF at one point)
    Also, the way you have it (Digits =~DCD i)
    Digits can only be
    11111110
    11111101
    11111011
    11110111
    Although it is late here, your code makes no sense to me
    However, if Digits does control the port, it looks like you can turn your DP on by issuing this
    Digits.7 = 0
    (provided the wire or trace from the DP goes to pin 7 of your port).
    Post complete code for better shot at guessing what you are trying to do.
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Feb 2003
    ok it's not 4am (it's 8:15am)
    i see what the dcd command is doing (common anode as you noted).
    For the digit you want to have the dp on try
    Sements.7 = 0 (provided your PORT.7 pin is tied to the DP via wire or trace
    Good Luck
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Feb 2003
    One more time - after a proper days rest, I have no clue what your code does; it looks to me to be partly written for common anode displays ($3F=1) and partly written for common cathode displays (Digits = ~DCD i). The Segments.7=0 should work (right after your lookup table) for the digit you want the DP to be on. Please post full code or schematic for more definite help.
    Again, Good Luck
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    May 2005
    Hi paul borgmeier
    Now I try to show temp with DS1820 on 7 seg 4 digit
    Below is code , I can read data temp from ds1820 and send to RS232 -->OK but canot to diplay to 7 Seg. Ex 29.05C
    Code :
    Define LOADER_USED 1
    @ Device pic16F877, xt_OSC, BOD_OFF, PWRT_ON, WDT_OFF, PROTECT_OFF,WRT_ON
    Segments Var PORTC
    Digits Var PORTD
    i Var Byte
    n Var Byte
    Value Var Word
    TRISc = $00 ' Set segment pins to output
    TRISd = $f0 ' Set digit pins to output
    ' Allocate variables
    command var byte ' Storage for command
    J var byte ' Storage for loop counter
    temp var word ' Storage for temperature
    DQ var PORTd.4 ' Alias DS1820 data pin
    DQ_DIR var TRISd.4 ' Alias DS1820 data direction pin
    TrisB = $00
    Portb = $00
    OPTION_REG = $55 ' Set TMR0 configuration 1:64
    INTCON = $A0 ' Enable TMR0 interrupts
    On Interrupt Goto display
    ADCON1 = 7 ' Set PORTA and PORTE to digital
    ' Lcdout $fe, 1, "Temp in degrees C" ' Display sign-on message
    'debug ====
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_SPBRG 12 ' 19200 Bauds ,4 m
    'debug ====
    ' Mainloop to read the temperature and display on LCD
    mainloop:
    Gosub init1820 ' Init the DS1820
    command = $cc ' Issue Skip ROM command
    Gosub write1820
    command = $44 ' Start temperature conversion
    Gosub write1820
    Pause 2000 ' Wait 2 seconds for conversion to complete
    Gosub init1820 ' Do another init
    Gosub write1820
    command = $be ' Read the temperature
    Gosub write1820
    Gosub read1820
    'Display the decimal temperature
    'Lcdout $fe, 1, dec (temp >> 1), ".", dec (temp.0 * 5), " degrees C"
    'HSEROUT ["Temp = ",dec (temp>>1),".", dec (temp.0*5)," C",13,10]
    Goto mainloop ' Do it forever
    ' Initialize DS1820 and check for presence
    init1820:
    Low DQ ' Set the data pin low to init
    Pauseus 500 ' Wait > 480us
    DQ_DIR = 1 ' Release data pin (set to input for high)
    Pauseus 100 ' Wait > 60us
    If DQ = 1 Then
    'Lcdout $fe, 1, "DS1820 not present"
    Pause 500
    Goto mainloop ' Try again
    Endif
    Pauseus 400 ' Wait for end of presence pulse
    ' Write "command" byte to the DS1820
    write1820:
    For j = 1 to 8 ' 8 bits to a byte
    If command.0 = 0 Then
    Gosub write0 ' Write a 0 bit
    Else
    Gosub write1 ' Write a 1 bit
    Endif
    command = command >> 1 ' Shift to next bit
    Next j
    ' Write a 0 bit to the DS1820
    write0:
    Low DQ
    Pauseus 60 ' Low for > 60us for 0
    ' Write a 1 bit to the DS1820
    write1:
    Low DQ ' Low for < 15us for 1
    @ nop ' Delay 1us at 4MHz
    Pauseus 60 ' Use up rest of time slot
    ' Read temperature from the DS1820
    read1820:
    For J = 1 to 16 ' 16 bits to a word
    temp = temp >> 1 ' Shift down bits
    Gosub readbit ' Get the bit to the top of temp
    Next J
    ' Read a bit from the DS1820
    readbit:
    temp.15 = 1 ' Preset read bit to 1
    Low DQ ' Start the time slot
    If DQ = 0 Then
    temp.15 = 0 ' Set bit to 0
    Endif
    Pauseus 60 ' Wait out rest of time slot
    '================== 7 seg ment display ==============================
    disable
    display:
    INTCON.2 = 0 'clear the interrupt flag
    VALUE = (temp >>1)+(temp.0 * 5)
    NEXT I
    goto mainloop
    display1:
    Lookup n, [$3F,$06, $5B, $4F, $66, $6D, $7D, $07, $7F, $6F, $77, $7C, $39, $5E, $79, $71], Segments
    Digits = ~Dcd i
    enable
    May 2005
    [QUOTE=chai98a;30011]Hi paul borgmeier
    Below is code , I can read data temp from ds1820 and send to RS232 -->OK but canot to diplay to 7 Seg. Ex 29.5C
    How to show number , dot and character on display ??
    Code :
    Segments Var PORTC
    Digits Var PORTD
    i Var Byte
    n Var Byte
    Value Var Word
    TrisB = $00
    Portb = $00
    'debug ====
    'debug ====
    mainloop:
    Gosub write1820
    Gosub write1820
    Gosub write1820
    Gosub write1820
    Gosub read1820
    init1820:
    If DQ = 1 Then
    Pause 500
    Endif
    write1820:
    Else
    Endif
    Next j
    write0:
    Low DQ
    write1:
    read1820:
    Next J
    readbit:
    If DQ = 0 Then
    Endif
    disable
    display:
    NEXT I
    goto mainloop
    display1:
    Digits = ~Dcd i
    enable
  1. Hdsp 21xx display
    By Original in forum mel PIC BASIC Pro
    Last Post: - 7th June 2012, 21:07
  2. LED Machine Tach For Tired Eyes
    By Archangel in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 15:55
  3. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 09:42
  4. DS1820 display with 7-seg 4 digits
    By chai98a in forum Code Examples
    Last Post: - 10th April 2008, 14:12
  5. 7 segment digit problem (using Mister E's code)
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 9th September 2005, 21:25
