no does not work
I tried other B port and they work.
I tried the analog ports like porta.0 and does not work.
Should all the analog ports be used just for analog ?
k
Unless you disable the analog capability... yesShould all the analog ports be used just for analog ?
As far as i remind of this chip PORTE<2:0> have multiplex analog stuff on that you have to disable first
those will help... but better if you refer to the datasheet to make sure of everything.Code:ADCON1=7 CMCON=7
that would include port e too?
I will need to use the analog port of portA later on too...
wouldn't that disable them ? Or do I need to find anothe rport for my serin command ?
I gues i have to play around with adcon (bit 0 to 3 )
Yes indeed!
Originally Posted by Datasheet section 4.5
