Serin serout problem
Results 1 to 40 of 337
    Sep 2006
    I actualy tried the 150 Ohm, and it gets hot just as fast.
    NO the regulator is installed correctlt, with the 12v pin (1) on the outside, far away of the IC.
    I cant play around too much with the circuit now, I will try it as is see, or get myself a 2amp regulator. Have to go to the store anyway to get an Lm331.
    thanks
    ken
    Sep 2006
    HI
    I am back working on my remote control code. I previously had two input for A/D. I needed to add another for my voltage checker. I used port B7 for the an6. or pin 13 on my pic16F88. When I dont put in the pic chi I read a voltage, say 0.8 volt. But when I put in the chip I do not read any voltage.
    I tried the same circuit on a bread board and it do not do that. Could it be hardware or software. here is bit of the code:
    just read below
    Sep 2006
    I finally found where the problem lies but dont know how to fix it. The led blinks but after 4-5 blinks, with the subroutine , it stops. If I dont put a subroutine it keeps on blinking. here is my program.
    thanks
    INCLUDE "modedefs.bas"
    @ DEVICE PIC16F88 , HS_OSC , WDT_OFF , PWRT_ON , BOD_ON , LVP_OFF , PROTECT_OFF
    DEFINE OSC 20 'use external 20mhz crystal
    CMCON = 7 : ANSEL = 0 : ADCON1 = 7
    Define ADC_BITS 8 ' Set number of bits in result
    ADCON1 = %00100010 ' Set PORTA analog and RIGHT justify result, ADCON1 = %10000010 for 10 bit
    ADCON0 = %10010010
    TRISA = %11111111 ' Set PORTA to all input
    TRISB = %10000000
    input1 var byte
    loop:
    ADCIN 6, input1
    pause 30
    if input1 > 255 then
    portb.3 =0
    goto blinker
    goto loop
    Blinker:
    portb.3 =1 ' Turn on LED connected to PORTB.6
    Pause 500 ' Delay for .5 seconds
    portb.3 =0 ' Turn off LED connected to PORTB.4
    Default What is the value of input 1?
    Quote Originally Posted by lerameur View Post
    thanks
    ADCON0 = %10010010
    TRISB = %10000000
    input1 var byte
    loop:
    ADCIN 6, input1
    pause 30
    portb.3 =0
    goto blinker
    goto loop
    Blinker:
    Hi leramuer,
    do you know the numerical value of input1 ?
    Maybe the code is doing exactly what you asked it to do.
    if input1 is greater than 255 shut off LED, if code is less then goto blinker,
    maybe add in a debug and check value of input 1 as far as pic understands value.
    edit: your comments in the blinker sub tripped me up, thought it was switching two different ports.
    edit2: input var byte
    if input > 255 then . . . 255 that's all a byte will hold . . . correct?
    should not you select a number that is smaller?
    Sep 2006
    The comments are irrelevant for the ports in this case.
    It blinks a few times then stps, thats why I dont understand. I will need to solder some wires and hook up a lcd to see what is happening.
    ken
    Here we observe a nice stack UNDERflow example...
    Change your GOTO Blinker to GOSUB Blinker
    OR change your RETURN FOR A GOTO Loop
    Sep 2006
    yes thats, I knew it was software , could not get my finger on it. Thanks, it works.
    Last Post: - 8th March 2010, 21:58
  2. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 23:03
  3. serout and serin problem
    Last Post: - 11th April 2006, 20:44
  4. Replies: 11
    Last Post: - 13th July 2005, 20:26
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 16:54
