Serin serout problem
Results 1 to 40 of 337
Threaded View
  1. #28
    Default Step by step
    Ok leramuer,
    Since I am too lazy to read 288 pages of this post over, I am not going to ASSUME anything. So here goes; Current flow, not to be mistaken with electron flow, current flows from positive to negative. The arrows in LEDs and Transistors indicate the current flow direction. Maybe you know all this, like I said, I will assume nothing. (1) Anyway, if you have a pic which outputs logic High, then you hook that port to pin 1 or pin 4 of the opto coupler, and pins 2,3 would hook to ground.(2) If ypur PIC outputs logic low then you would hook the port to pin 2 or 3, pins 1 and 4 would hook to the positive supply. now if your relay has one leg hooked to positive then the other leg would hook to pin 6, or 7.
    If your relay has one leg hooked to ground, then the other end should hook to pin 5 or eight. As I said current flows in the direction the arrows point. It is that simple. CAUTION: Be sure to use current limiting resistors on the emitter side of the opto couplers as they only operate at 1.5v max 20ma so as not to fry them.
    Last Post: - 8th March 2010, 21:58
  2. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 23:03
  3. serout and serin problem
    Last Post: - 11th April 2006, 20:44
  4. Replies: 11
    Last Post: - 13th July 2005, 20:26
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 16:54
