Serin serout problem
Results 1 to 40 of 337
    Quote Originally Posted by lerameur View Post
    as for the lCd that is entirely my fault,
    but are you saying opto couplers are not necessary?
    when should they be used. ?
    i just read a few reports of similar problem that where resolved this way.
    pic:
    http://www3.sympatico.ca/lerameur/PDR_0141.jpg
    Sorry guy...I can't make heads or tails of the picture in your last post.
    Sep 2006
    I decided i am going to put relays instead of an H-bridge.
    I recently obtained some nice sensors from Taosinc.com. I wrote this program but it does not work. The datasheet is not complicated, but maybe I missed something. I seems that i need to put SI to high after the 129th clock. maybe I am not using the pulsin command right.
    datasheet:
    http://www.taosinc.com/images/produc...401R-LF-E4.PDF
    My program:
    sensor var byte: counter var byte : pulse var byte
    TRISB = %00000000
    TRISA = %11111111
    loop:
    'clock input on RB0
    'after 18 clock input at 1, count 111 clock cycles after the reset
    pulse = 0
    counting:
    Pulsin PortA.1,1,pulse
    pulse = pulse +1
    if pulse = 18 then goto continue
    goto counting
    continue:
    pulse = pulse +1
    if pulse = 130 then goto continue2
    goto counting
    continue2:
    porb.0 = 1 'Si is now high
    pulse = pulse +1
    if pulse = 131 then goto continue3
    goto continue2
    continue3:
    ADCON0.2 = 1 'Start Conversion
    porb.0 = 0 'put the SI back to zero
    ADCIN 0, sensor 'Read channel PORTA.0
    pause 50
    Lcdout $fe, 1 'Clear screen
    Lcdout "Sensor: ", Dec sensor
    Pause 200
    goto loop
    Sep 2006
    Default opto coupler
    I have bought the MCT6 chip (opto coupler)
    I grounded pin 3 and 5
    If I put a voltage a cross pin 4 should I get the same voltage across pin 6 ??
    NO. here is a link to the data sheet'
    http://www.fairchildsemi.com/ds/MC/MCT62.pdf
    Sep 2006
    I actually did the the circuit shown on page 5
    http://www.ortodoxism.ro/datasheets/vishay/83645.pdf
    still do not work.
    Default Step by step
    Ok leramuer,
    Since I am too lazy to read 288 pages of this post over, I am not going to ASSUME anything. So here goes; Current flow, not to be mistaken with electron flow, current flows from positive to negative. The arrows in LEDs and Transistors indicate the current flow direction. Maybe you know all this, like I said, I will assume nothing. (1) Anyway, if you have a pic which outputs logic High, then you hook that port to pin 1 or pin 4 of the opto coupler, and pins 2,3 would hook to ground.(2) If ypur PIC outputs logic low then you would hook the port to pin 2 or 3, pins 1 and 4 would hook to the positive supply. now if your relay has one leg hooked to positive then the other leg would hook to pin 6, or 7.
    If your relay has one leg hooked to ground, then the other end should hook to pin 5 or eight. As I said current flows in the direction the arrows point. It is that simple. CAUTION: Be sure to use current limiting resistors on the emitter side of the opto couplers as they only operate at 1.5v max 20ma so as not to fry them.
    Sep 2006
    ok I am getting the voltage now
    I will be using this to ativate my h-bridge.
    also, I am trying to solder a small capacitor (0.1uF) on the terminal of my motor. The solder does not want to stay eith on the pin of the case of the motor, do you have any trick here?
    Last Post: - 8th March 2010, 20:58
  2. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 22:03
  3. serout and serin problem
    Last Post: - 11th April 2006, 19:44
  4. Replies: 11
    Last Post: - 13th July 2005, 19:26
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 15:54
