Serin serout problem
Results 1 to 40 of 337
    Sep 2006
    yes it does have a backlioght.
    The supply is a 12v battery cannot put that directly on thebattery
    Feb 2003
    Quote Originally Posted by lerameur View Post
    Do you have a series resistor between your 5v supply and the LCD backlight?
    If not it will be drawing excessive current which will definately be why the 7805 is cooking.
    If you do have a resistor, then increase its value and drive the backlight from the 12v supply. Search for threads about "backlight", one just resurfaced in the last couple of days.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Sep 2006
    i have a potenetiometer between the 5 v and the LCD, I swiched to the 12v with the pot, and the LCD is finished
    Feb 2003
    Sorry to hear that you toasted the LCD but I didnt suggest running the LCD from the 12v supply.... just the backlight.
    If you had read the other threads about this you would see the reason behind it. The LCD only takes a couple of milliamps but the backlight takes 50-80mA which is a lot of extra for the regulator to handle.
    The backlight doesnt need a regulated supply, just a current limited one hence the use of a series resistor which you calculate according to the forward voltage of the backlight , the required current through the backlight and the maximum voltage of the unregulated supply.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Sep 2006
    a ok , i get it,
    By the way , anybody knows why My h_bridge, L298N get really really hot even with a heat sink and just 1.8 amp ?and yes it is connected to the 12v battery. Getting hot, and its not working anymore...
    Default Country Fried
    a ok , i get it,
    Hi Leramuer, sounds like the magic smoke escaped from that device. 12v x 1.8 a
    = 21.6 watts, I assume thats the running current under normal load. That figure increases exponentialy when you reverse direction and that's a whole lot of heat. What do you have for a heat sink? Maybe in addition to more heat sink you should put in a thermal shutdown circuit.
    JS
    a ok , i get it,
    If it was me doing a project needing an H-bridge, I'd skip the H-bridge and just go with a set up using a bunch of logic-level N-channel enhancement mode MOSFETs (try saying that 3 times fast), or P-channel, whatever. That way I know for sure I can drive whatever it is I need to drive. And if the MOSFETs get too hot even after putting a heatsink on them, you can always parallel them. Which gets me to thinking...have you tried paralleling a couple of L298N's? I haven't read the datasheet, don't know if it's possible (or even wise)...might work though.
    And 12v @ 1.8a does = 21.6watts, but only if the L298N has resistance across it, zero resistance = zero load. Maybe the L298N isn't being driven hard enough. (Sounds like it's time to get my butt over to the datasheets so I know what I'm talking about here).
    Sep 2006
    I have a big ass heat sink, about 9 times he size of the chip.
    I believe I was under th wattage recommended (or maybe just on it, cause the battery was fully charged at 12.85 and @ 1.9 amp 24.7 watt.
    would that of killed it.
    I looked at comse circuit for making my own H-bridge, but is seems a bit messy.
    I have some IRFZ44N N mos, maybe get their brother P's and work with that, you have any schematic ?
    I found this: http://www.armory.com/~rstevew/Publi...d/nch-brdg.htm
    but I dont know
    update:
    I tried one IRFZ44N , it become very hot with just 5watt. I know I can put a heat sink, but this thing is suppose to support 94 watt. Is there somehting I am not getting ??
    Last Post: - 8th March 2010, 21:58
  2. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 23:03
  3. serout and serin problem
    Last Post: - 11th April 2006, 20:44
  4. Replies: 11
    Last Post: - 13th July 2005, 20:26
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 16:54
