Serin serout problem
Results 1 to 40 of 337
    Sep 2006
    HI,
    I am almost finish writing my code and I get an error at the receivring end, I have an LCDout and the sending end, it good number, but at the receiving end the information is confused.
    meaning the Left is showing the same thing as the sending left.
    But the right is showing me number like 12421 (pot at center). I encode and decode he same way, This is weird. what also struck me is that number 12421 is constant, so that when I move my pot there is a variation from 12542 to 12288 .
    I also flipped the serin line for left and right and i get the same result..
    (the sending and show number varying between 0 to 255)
    here is a snippet of the code:
    right var word : left var word : temp var word : counter var byte
    rightold var word : leftold var word : speedright var word : speedleft var word
    loop:
    waitfor55:
    serin portb.2 , n2400 , temp
    if temp <> $55 then goto waitfor55
    waitforaa:
    serin portb.2 , n2400 , temp : if temp <> $aa then goto waitforaa
    serin portb.2, n2400, rightold.LowBYTE : serin portb.2, n2400, rightold.HighBYTE
    serin portb.2, n2400, leftold.LowBYTE : serin portb.2, n2400, leftold.HighBYTE
    For counter=0 TO 7 'decoding
    left.0[counter]=leftold.0[counter*2]
    right.0[counter]=rightold.0[counter*2]
    Next counter
    Lcdout $fe, 1 'Clear screen
    Lcdout "Left: ", Dec left
    Lcdout $fe, $C0, "Right: ", DEC right
    Pause 100
    before you ask, here is my sending part:
    send:
    serout portb.2, n2400,[$55,$55,$55,$55,$55,$55,$55,$55,$aa]
    serout portb.2, n2400,[rightnew.LowBYTE,rightnew.HighBYTE]
    serout portb.2, n2400,[leftnew.LowBYTE,leftnew.HighBYTE]
    goto loop
    Sep 2006
    it works now, changed some word to byte ...
    Sep 2006
    Hey , I just realize that after running my receiving circuit for a minute or so , he Lm7805 gets very hot, Is this normal ?. on my sending circuit it stays cool.
    I have on the receiving, an lcd, the receiving RF module, a Pic16F877a and an H-Bridge.. The H bridge is running directly from the battery for the Vs. everything is battery operated
    Feb 2003
    Quote Originally Posted by lerameur View Post
    Does the LCD have a backlight ?
    If so, try running it from the unregulated power supply after increasing the resistor accordingly.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Sep 2006
    yes it does have a backlioght.
    The supply is a 12v battery cannot put that directly on thebattery
    Feb 2003
    Do you have a series resistor between your 5v supply and the LCD backlight?
    If not it will be drawing excessive current which will definately be why the 7805 is cooking.
    If you do have a resistor, then increase its value and drive the backlight from the 12v supply. Search for threads about "backlight", one just resurfaced in the last couple of days.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Sep 2006
    i have a potenetiometer between the 5 v and the LCD, I swiched to the 12v with the pot, and the LCD is finished
    Last Post: - 8th March 2010, 20:58
  2. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 22:03
  3. serout and serin problem
    Last Post: - 11th April 2006, 19:44
  4. Replies: 11
    Last Post: - 13th July 2005, 19:26
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 15:54
