Serin serout problem
Results 1 to 40 of 337
    Quote Originally Posted by lerameur View Post
    ok I am doing a remote control for my robot I wrote a code below, It seems long, Maybe you have a better idea. I am using two Potentiometer , the values of each will control the left and right motor of the robot:
    'Remote control*****************
    direction var word : speed var word
    Loop:
    If (left => 115) AND (left <= 135) AND (right => 115) AND (right <= 135) then
    goto stop
    If (left => 115) AND (left <= 135) AND (right <= 115) then 'left is stop, right is CCW
    goto LeftstopRightCCW
    If (left => 115) AND (left <= 135) AND (right => 135) then 'left is stop , right is CW
    goto LeftstopRightCW
    If (right => 115) AND (right <= 135) AND (right <= 115) then 'right is stop, left is CCW
    goto RightstopLeftCCW
    If (right => 115) AND (right <= 135) AND (right => 135) then 'right is stop , left is CW
    goto RightstopLeftCW
    If (left > 135) AND (right > 135) then 'Left Cw & right CW
    goto LeftCWRightCW
    If (left > 135) AND (right < 135) then 'Left CW & right CCW
    goto LeftCWRightCCW
    If (left < 135) AND (right > 135) then 'Left CCW & right CW
    goto LeftCCWRightCW
    If (left < 135) AND (right < 135) then 'Left CCW & right CCW
    goto LeftCCWRightCCW
    In brief:
    'Stop '--------------------------------$69 = 01 10 10 01
    'Leftwheel =stop : Rightwheel= CCW '--- $A6 = 10 10 01 10
    'Leftwheel =stop : Rightwheel= CW '----- $96 = 10 01 01 10
    'Leftwheel =CCW : Rightwheel= stop '---- $9a = 10 01 10 10
    'Leftwheel =CW : Rightwheel= stop '----- $A5 = 10 10 01 01
    'Leftwheel =CW : Rightwheel= CW '---- $66 = 01 10 01 10
    'Leftwheel =CW : Rightwheel= CCW '---- $56 = 01 01 01 10
    'Leftwheel =CCW : Rightwheel= CW '---- $5a = 01 01 10 10
    'Leftwheel =CCW : Rightwheel= CCW '---- $65 = 01 10 01 01
    You're right. There probably is a better/shorter way to do that.
    I'll think about it for a bit and get back to ya.
    I take it that the reason you've got 115 and 135 is for a bit of a 'deadband' so the thing doesn't jitter on you?
    (see that?, the manchester encoding is handy isn't it?)
    How about
    bits var byte
    'bits = bit7 bit6 bit5 bit4 bit3 bit2 bit1 bit0
    ' LCW (-LCW) LCCW -(LCCW) RCW (-RCW) RCCW (-RCCW)
    'use odd bits as a direction flag, use the even bits inverted from the others as the same thing, but also as a bit of error detection
    TX end...
    Loop:
    bits = %01010101
    If (left => 115) AND (left <= 135) then bits.7 = 0 : bits.6 = 1
    if (right => 115) AND (right <= 135) then bits.3 = 0 : bits.2 = 1
    if (right <= 115) then bits.1 = 1 : bits.0 = 0
    If (right => 135) then bits.3 = 1 : bits.2 = 0
    If (left <= 115) then bits.5 = 1 : bits.4 = 0
    If (left => 135) then bits.7 = 1 : bits.6 = 0
    transmit
    goto loop
    RX end....
    In brief:
    if bits.7 = bits.6 then bitserror 'bit pairs shouldn't be equal
    if bits.5 = bits.4 then bitserror
    if bits.3 = bits.2 then bitserror
    if bits.1 = bits.0 then bitserror
    And at the receiver end, the receiver code wouldn't actuate a motor until receiving a few correct codes in a row (a one time code wouldn't trip the motors into running).
    Just a quick thought I had...
    Sep 2006
    I got the module working now, I will be doing some testing thursday.
    by the way i wouls like to have a crystal oscillate by itself, How do i do that ? I have a sensor chip that needs to be clocked. I tried connecting it to + and ground but nothing
    Crystals don't oscillator by themselves. In short, you have to have a small inverting amp, induce a phase shift, and a few other things to get a usable signal from them. Grab the datasheet for a 4066 and see what they do with a crystal and one of those chips. Or just buy a DIP oscillator of the frequency of your choice (Digikey ECS oscillators).
    Sep 2006
    I got the oscillator goimg, Its square wave, I will be adding a couple of caps and resisor to make it more like a sin wave.
    Also I needed more memory for my project so I got the monster Pic18F4685. Iuse the same program as for the Pic16F877a and it gives errors about the nbit number, I guess I have to change all the specification of my program. but I am not sure what; here is the message i am getting after compiling:
    C:\PBP>pbp -p18F4685 motorG
    PICBASIC PRO(TM) Compiler 2.47, (c) 1998, 2006 microEngineering Labs, Inc.
    All Rights Reserved.
    PM Assembler 4.08, Copyright (c) 1995, 2006 microEngineering Labs, Inc.
    Error 18F4685.INC 14 : [235] Opcode Expected Instead of 'Error: PM does not sup
    port this device. Use MPASM.'
    Error C:\PBP\MOTORG.ASM 85 : [225] Undefined Symbol 'PORTB'
    Error C:\PBP\MOTORG.ASM 86 : [225] Undefined Symbol 'PORTC'
    Error C:\PBP\MOTORG.ASM 87 : [225] Undefined Symbol 'TRISB'
    Error C:\PBP\MOTORG.ASM 88 : [225] Undefined Symbol 'TRISC'
    Error PBPPIC18.LIB 161 : [225] Undefined Symbol 'PORTB'
    Error PBPPIC18.LIB 379 : [225] Undefined Symbol 'PORTB'
    Error PBPPIC18.LIB 1153 : [200] Instruction Restricted to 14-Bit Core
    Error PBPPIC18.LIB 1153 : [218] Address Limit of FFFFh Exceeded
    Error PBPPIC18.LIB 1158 : [200] Instruction Restricted to 14-Bit Core
    Error PBPPIC18.LIB 1158 : [218] Address Limit of FFFFh Exceeded
    Error PBPPIC18.LIB 1281 : [200] Instruction Restricted to 14-Bit Core
    Error PBPPIC18.LIB 1281 : [218] Address Limit of FFFFh Exceeded
    Error PBPPIC18.LIB 1282 : [200] Instruction Restricted to 14-Bit Core
    Error PBPPIC18.LIB 1282 : [218] Address Limit of FFFFh Exceeded
    Fatal PBPPIC18.LIB 1282 : [300] Too Many Errors
    C:\PBP>
    C:\PBP>
    Check your PBP manual. You can't use the assembler that comes with PBP, gotta use MPASM for the PIC18Fxxxx parts.
    Sep 2006
    O ok, because i saw the .BAS and .INC files, so I thougt it would take it.
    alright
    Sep 2006
    HI,
    I am almost finish writing my code and I get an error at the receivring end, I have an LCDout and the sending end, it good number, but at the receiving end the information is confused.
    meaning the Left is showing the same thing as the sending left.
    But the right is showing me number like 12421 (pot at center). I encode and decode he same way, This is weird. what also struck me is that number 12421 is constant, so that when I move my pot there is a variation from 12542 to 12288 .
    I also flipped the serin line for left and right and i get the same result..
    (the sending and show number varying between 0 to 255)
    here is a snippet of the code:
    right var word : left var word : temp var word : counter var byte
    rightold var word : leftold var word : speedright var word : speedleft var word
    loop:
    waitfor55:
    serin portb.2 , n2400 , temp
    if temp <> $55 then goto waitfor55
    waitforaa:
    serin portb.2 , n2400 , temp : if temp <> $aa then goto waitforaa
    serin portb.2, n2400, rightold.LowBYTE : serin portb.2, n2400, rightold.HighBYTE
    serin portb.2, n2400, leftold.LowBYTE : serin portb.2, n2400, leftold.HighBYTE
    For counter=0 TO 7 'decoding
    left.0[counter]=leftold.0[counter*2]
    right.0[counter]=rightold.0[counter*2]
    Next counter
    Lcdout $fe, 1 'Clear screen
    Lcdout "Left: ", Dec left
    Lcdout $fe, $C0, "Right: ", DEC right
    Pause 100
    before you ask, here is my sending part:
    send:
    serout portb.2, n2400,[$55,$55,$55,$55,$55,$55,$55,$55,$aa]
    serout portb.2, n2400,[rightnew.LowBYTE,rightnew.HighBYTE]
    serout portb.2, n2400,[leftnew.LowBYTE,leftnew.HighBYTE]
    goto loop
    Last Post: - 8th March 2010, 21:58
  2. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 23:03
  3. serout and serin problem
    Last Post: - 11th April 2006, 20:44
  4. Replies: 11
    Last Post: - 13th July 2005, 20:26
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 16:54
