Quote Originally Posted by lerameur View Post
What do you mean by OSC 20 doesn't work? Compile error? Timing wrong?
No oscillation on the scope... thast why
2) yes, you can put the LCD data lines anywhere you CAN define them.
Did you try an led blink yet?
I will try it
PIC16F876A and 16F88 should operate the same as far as PBP is concerned.
Why not use port D like usual?
NO por D onthat chip, I tried portC 4 to & , no differnce
You said in post 236 you got the oscillation going.
Port D - DOH!!!! I knew that...I was just checking you...yeah that's it, just checking...
