Serin serout problem
Results 1 to 40 of 337
    Sep 2006
    hi,
    Ok I got the A/D working now.
    I bought another RF module kit from this web site:
    http://www.robotshop.ca/home/product...ity-tx-rx.html
    ( actuallyI just had to drive there).
    I use the exact program and configuraiton and I am getting contact output on the lcd :
    TempC : 0
    TempF: 32
    here is what I see on the scope:
    http://www3.sympatico.ca/lerameur/
    Quote Originally Posted by lerameur View Post
    hi,
    I use the exact program and configuraiton and I am getting no ouput
    A/D is working as expected? Values are what you need and all that?
    RF Modules - sounds like you should take them back and get another pair of the same thing you've already got.
    Sep 2006
    I bought three pair of them , They all act the same...
    it looks ok from the scope doesn't it ??
    Yes
    Yes
    Put the old ones back in and snap a pic of those, put the 2 pic's up side by side. Maybe one is inverted from the other or something.
    Sep 2006
    I did that they are almost the same on the scope.
    Almost apparently isn't close enough.
    Fatten up the traces a bit if you can and repost the pics including the original RF module sets.
    Also, you might want to try speeding up the TX rate, maybe a couple more sync bytes ($55), maybe less, who knows.
    That's the problem with getting something to work with one thing, and then using another, you gotta redo practically everything.
    Sep 2006
    Ok I posted a picture of the working module, I bit different.
    same link
    Last Post: - 8th March 2010, 21:58
  2. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 23:03
  3. serout and serin problem
    Last Post: - 11th April 2006, 20:44
  4. Replies: 11
    Last Post: - 13th July 2005, 20:26
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 16:54
