Serin serout problem
Results 1 to 40 of 337
    Sep 2006
    another thing, I get (sometimes) wired values on the receiver. I read the temperature good, but once in a whjile, I get 2 temperature reading on one line, other ime i get +200, etc...
    does this have to do with the system being wireless, or the fact that my encoding technique is weak and prone to mistakes??
    Sep 2006
    HI I did the test , as I suspected, I get 0.7v all the time. So I caould put a few in a row to get a higher voltage difference and use that as a reference voltage.
    Quote Originally Posted by lerameur View Post
    You could, but those diodes will vary in voltage with time, temperature, current flow, moon phases, etc, not by much, but they will change over time and temperature at least, and in series, they'd do nothing but get worse. Therefore, you're battery voltage reading will change accordingly, and probably screw you up in the long run. And you have to have X amount of current to even get the diodes to conduct. You might end up using more power than you would really want to just to get a reading.
    Have you been able to get the A/D working yet?
    Like I said, spare pin to a resistor (probably 1K or so), other side of resistor to non-banded side of diode, banded side of diode to ground. Tap the non-banded side to your A/D port and take some readings with the battery hooked up as normal and A/D converter set up with Vref+ at Vdd and Vref- at Vss. If you're using the 10bit A/D, you should get a reading arorund 150-ish. Then as the battery wears down, the reading will go up. A reading of roughly 200 will mean a dead battery.
    And, you can save the power to read the battery by change that 'spare pin' mentioned above to an input and shutting off the A/D module.
    Sep 2006
    ok , I have a problem now:
    i wrote this program below, I configured so it read porta.0, but I get 0 output when I ground it and oscillation between 890 and to 900 when i put it to Vdd.
    if I leave the program as is, and just put the input wire to portA.1 theni get 0 output when i groud the wire, and 1023 when I put it to Vdd.
    Why am I getting a better result to a non configured port 6, at least i am ot calling this pin ??
    my ADCON0 = %10000001 i believe this is for An0 to input
    I am also trying to get two input for A/d , is that possible ?
    'RECEIVE PIC
    INCLUDE "modedefs.bas"
    DEFINE OSC 20 'use external 20mhz crystal
    DEFINE LCD_DREG PORTB ' Set LCD Data port
    DEFINE LCD_DBIT 4 ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_RSREG PORTB ' Set LCD Register Select port
    DEFINE LCD_RSBIT 1 ' Set LCD Register Select bit
    DEFINE LCD_EREG PORTB ' Set LCD Enable port
    DEFINE LCD_EBIT 0 ' Set LCD Enable bit
    DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 2 ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2500
    'DEFINE LCD_DATAUS 250
    'DEFINE CHAR_PACING 2000
    ' Define ADCIN parameters
    Define ADC_BITS 10 ' Set number of bits in result
    input1 var word : input2 var word
    TRISA = %11111111 ' Set PORTA to all input
    CMCON = 7
    ANSEL = %00001100
    ADCON1 = %10000010
    ADCON0 = %10000001
    Pause 500
    loop: ADCIN porta.0, input1
    Lcdout $fe, 1 ' Clear LCD
    Lcdout "Value1: ", DEC input1 ' Display the decimal value
    lcdout $FE,$C0, "Value2: ", dec input2
    Pause 200
    Goto loop
    Also, what do you mean by : Spare pin to resistor ?
    Sep 2006
    trying to get multiple input,but getting wrong values
    loop:
    ADCON0 = %10000001 ' Configure and turn on A/D Module
    pause 50
    ADCON0 = %10001001 ' Configure and turn on A/D Module
    ADCIN porta.1, input2
    pause 50
    Pause 400
    Goto loop
    'RECEIVE PIC
    CMCON = 7
    ANSEL = %00001100
    ADCON1 = %10000010
    ADCON0 = %10000001
    Pause 500
    Pause 200
    Goto loop
    Oscillation - I get that too on most everything I do on the A/D inputs (I don't know if it's a function of crappy circuit boards or bad design, doesn't matter to me anyways). You're probably going to want to do some sort of software averaging and/or put a capacitor across the input line to smooth it out a bit.
    Spare pin on resistor - instead of putting the diode direct to battery power, thru a resistor to ground, you can intermittently power that diode thru a spare PIC output pin and save that power. Every little bit helps ya know.
    Sep 2006
    ok, but what about this loop here, can i do that, having multiple a/d conversion on one chip ?
    loop:
    pause 50
    pause 50
    From the definition of ADCON0, I can only choose one pin for A/D conversion. Maybe thats why it get mixed up .
    loop:
    pause 50
    pause 50
    You can do A/D on more than one pin, just not at the same time. I'm not sure why it didn't work for you in the one post. Maybe not waiting long enough between conversions and/or long enough between switching A/D channel assignment. I think you have to wait awhile, not only after the last conversion, but after you switch the channel, which ADCIN does for you. So, again, not sure. I'll think on it. Until then, double check your configuration, TRIS assignments, ADCON setup, etc.etc.
    And you shouldn't have to use more than one channel for your project, unless I missed something there too...
    Last Post: - 8th March 2010, 21:58
  2. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 23:03
  3. serout and serin problem
    Last Post: - 11th April 2006, 20:44
  4. Replies: 11
    Last Post: - 13th July 2005, 20:26
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 16:54
