Serin serout problem
Results 1 to 40 of 337
    Quote Originally Posted by lerameur View Post
    temperature = ( ~ temperature ) + 1 : tempf = ( ~ tempF ) + 1 ' added this
    lcdout $FE,1, "TempC: ", "-", dec (temperature / 100) , ".", dec2 temperature," ",$DF,"C"
    lcdout $FE,$C0, "TempF: ", "-", dec (tempF / 100) , ".", dec2 tempF ," ",$DF,"F"
    goto loop
    That 2nd conversion is done twice... once after Zerotemp & once after ZeroF.
    Sep 2006
    O yes, I removed it, anyway I cant test that cold yet
    No, but you can simulate it at the transmitter end with a loop instead of reading the temp sensor....duh!!!
    Just set up the transmitter to send out a slowly changing temperature that goes up the scale, resets to the low end, climbs back up again, whatever works for you.
    Or do it at the receiver end, put a couple of buttons in there, one button-temp goes up, another button-temp goes down.
    Sep 2006
    ok , I get that now,
    I want to concentrate on the cold but not that cold part for now.. the sensor is sticking outsid now, its about -11C
    I wanted to see what was behing calculated..
    The 2's compliment, the binary value gives me a good degree (tempc)
    when I put it in the equation it then screws up, I think the 2 byte count_per_c AND count_remain and different since it is in negative mode... hummm
    Nothing is siad about this in the specsheet either, and the program on Rentron does not use that part.
    here is the code:
    Zerotemp: '------------- cases when zero celcius and positive Fahrenheit
    temp1 = temperature
    temperature = ( ~ temperature ) + 1 '----- do this later, right before displaying it
    tempc =temperature
    temperature = ((( temperature ) *100)- 25) + (((count_per_c - count_remain) * 100) / count_per_c)
    tempF = ((temperature /5) * 9) + 3200
    if tempF <= 0 then goto ZeroF
    lcdout $FE,1, dec temp1 , ".", dec temperature ," ",$DF,"C"
    lcdout $FE,$C0, dec temperature, dec tempc , ".", dec tempc/2 ," ",$DF,"F"
    goto loop
    Sep 2006
    putting the 2,s compliment just befire works best:
    but the temperature seems to cut in half,, showing -5C when it is -10C
    Just getting +655 when I get to zero degrees.
    loop:
    '23
    waitfor55:
    serin portb.2 , n2400 , temp : if temp <> $55 then goto waitfor55
    waitforaa:
    serin portb.2 , n2400 , temp : if temp <> $aa then goto waitforaa
    serin portb.2, n2400, encoded11.HighBYTE : serin portb.2, n2400, encoded11.LowBYTE
    serin portb.2, n2400, encoded22.HighBYTE : serin portb.2, n2400, encoded22.LowBYTE
    serin portb.2, n2400, encoded33.HighBYTE : serin portb.2, n2400, encoded33.LowBYTE
    serin portb.2, n2400, encoded44.HighBYTE : serin portb.2, n2400, encoded44.LowBYTE
    For counter=0 TO 7 'decoding
    encoded1.0[counter]=encoded11.0[counter*2] : encoded2.0[counter]=encoded22.0[counter*2]
    encoded3.0[counter]=encoded33.0[counter*2] : encoded4.0[counter]=encoded44.0[counter*2]
    Next counter
    '41
    temperature= encoded1 ' putting back together as the original temperature
    For counter=0 TO 7
    temperature.0[counter+8]=encoded2.0[counter+8]
    Next counter
    temperature.LowBYTE = encoded1
    temperature.HighBYTE = encoded2
    count_remain = encoded3
    count_per_c = encoded4
    IF temperature.11 = 1 Then goto Zerotemp
    temperature = ((( temperature >> 1) *100)- 25) + (((count_per_c - count_remain) * 100) / count_per_c)
    tempF = (((temperature /5) *9 ) + 3200)
    lcdout $FE,1, "TempC: ", "+", dec (temperature / 100) , ".", dec2 temperature," ",$DF,"C"
    lcdout $FE,$C0, "TempF: ", "+", dec2 (tempF / 100) , ".", dec2 (tempF // 100)," ",$DF,"F"
    goto loop
    temp1 = temperature
    temperature = ((( temperature >>1 ) *100)- 25) + (((count_per_c - count_remain) * 100) / count_per_c)
    temperature = ( ~ temperature ) + 1 ': tempf = ( ~ tempF ) + 1 ' added this
    tempF = 3200 - ((temperature /5) * 9)
    lcdout $FE,$C0, "TempF: ", dec (tempF / 100) , ".", dec2 tempF ," ",$DF,"F"
    goto loop
    ZeroF: '---------------- cases when zero celcius and 0 Fahrenheit
    goto loop
    temp1 = temperature
    goto loop
    Why are you using:tempF = 3200 - ((temperature /5) * 9)
    instead of tempF = ( ( ( temperature / 5 ) * 9 ) + 3200 ) ?
    The positive case (the only one that's working) uses the +3200, the negative cases are using the 3200-.....
    What's the deal there?
    Sep 2006
    simple I need to take the difference. I believe pic basic pro can only handle unsigned numbers. So but keeking the original forula we get negative number for zero temperature. So by putting the 3200 in front , we get a positive number and add a minus sign.
    for -15 degrees celcius
    we have 15*100 =1500 in the euqation
    =3200 - (1500/5*9) = 500
    = 500/100 ------divide by hundred caus ewe multiplied by a 100 initially
    =5
    = -5 ----- here we just add the minus
    but anyway , remember when i said my decimal values was going reverse. I was thinking and that is similar from doing 2,s compliment . so i decided to do 2,s compliment on everything..
    count_per_c = ( ~ count_per_c) + 1
    count_remain= ( ~count_remain) + 1
    temp1 = temperature
    goto loop
    goto loop
    Last Post: - 8th March 2010, 20:58
  2. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 22:03
  3. serout and serin problem
    Last Post: - 11th April 2006, 19:44
  4. Replies: 11
    Last Post: - 13th July 2005, 19:26
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 15:54
