its all good now, exept foe that part between 0 to -5 degrees celcius,
There is no grey area, if the bit 11 os 1, then goto zerotemp, the math is the same for -1 C or -10C....
'RECEIVE PIC
INCLUDE "modedefs.bas"
DEFINE OSC 20 'use external 20mhz crystal
CMCON = 7 : ANSEL = 0 : ADCON1 = 7
DEFINE LCD_DREG PORTA ' Set LCD Data port
DEFINE LCD_DBIT 0 ' Set starting Data bit (0 or 4) if 4-bit bus
DEFINE LCD_RSREG PORTB ' Set LCD Register Select port
DEFINE LCD_RSBIT 1 ' Set LCD Register Select bit
DEFINE LCD_EREG PORTB ' Set LCD Enable port
DEFINE LCD_EBIT 0 ' Set LCD Enable bit
DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits)
DEFINE LCD_LINES 2 ' Set number of lines on LCD
DEFINE LCD_COMMANDUS 2500
DEFINE LCD_DATAUS 250
DEFINE CHAR_PACING 2000
counter var byte : temperature var word : encoded1 var word : encoded2 var word : encoded3 var byte
encoded11 var word : encoded22 var word : encoded33 var word : encoded44 var word : encoded4 var byte
count_remain var byte : count_per_c var byte : temp var word : tempc var byte : tempF var word
temperature1 var word
pause 2000
loop:
'23
waitfor55:
serin portb.2 , n2400 , temp : if temp <> $55 then goto waitfor55
waitforaa:
serin portb.2 , n2400 , temp : if temp <> $aa then goto waitforaa
serin portb.2, n2400, encoded11.HighBYTE : serin portb.2, n2400, encoded11.LowBYTE
serin portb.2, n2400, encoded22.HighBYTE : serin portb.2, n2400, encoded22.LowBYTE
serin portb.2, n2400, encoded33.HighBYTE : serin portb.2, n2400, encoded33.LowBYTE
serin portb.2, n2400, encoded44.HighBYTE : serin portb.2, n2400, encoded44.LowBYTE
For counter=0 TO 7 'decoding
encoded1.0[counter]=encoded11.0[counter*2] : encoded2.0[counter]=encoded22.0[counter*2]
encoded3.0[counter]=encoded33.0[counter*2] : encoded4.0[counter]=encoded44.0[counter*2]
Next counter
'41
temperature= encoded1 ' putting back together as the original temperature
For counter=0 TO 7
temperature.0[counter+8]=encoded2.0[counter+8]
Next counter
temperature.LowBYTE = encoded1
temperature.HighBYTE = encoded2
count_remain = encoded3
count_per_c = encoded4
IF temperature.11 = 1 Then goto Zerotemp
temperature = ((( temperature >> 1) *100)- 25) + (((count_per_c - count_remain) * 100) / count_per_c)
tempF = (((temperature /5) *9 ) + 3200)
lcdout $FE,1, "TempC: ", "+", dec (temperature / 100) , ".", dec2 temperature," ",$DF,"C"
lcdout $FE,$C0, "TempF: ", "+", dec2 (tempF / 100) , ".", dec2 (tempF // 100)," ",$DF,"F"
goto loop
Zerotemp: ' cases when zero celcius and positive Fahrenheit
temperature = temperature >> 1 'removing lowest bit
temperature1 = temperature
for counter = 0 to 6
if temperature.0[counter] = 1 then
temperature.0[counter] = 0
next counter
temp = temp + 1 ' 2,s compliment ends by adding a one
temp = temp >> 5
temperature = ((( temp ) *100)- 25) + (((count_per_c - count_remain) * 100) / count_per_c)
tempF = 3200 -((temperature /5) * 9)
if tempF = 0 then goto ZeroF
lcdout $FE,1, "TempC: ", "-", dec (temperature / 100) , ".", dec2 temperature," ",$DF,"C"
lcdout $FE,$C0, "TempF: ", dec (tempF / 100) , ".", dec2 tempF ," ",$DF,"F"
goto loop
ZeroF: ' cases when zero celcius and 0 Fahrenheit
lcdout $FE,$C0, "TempF: ", "-", dec (tempF / 100) , ".", dec2 tempF ," ",$DF,"F"
goto loop
