actually I did, th e pic is back , i will do another one with the last circuit
I just tried sending a constant over, and displaying it on the receiving end and it still gives me zero, maybe breaking the program into even more basic ?
new PIC online
with this last program, both counters are working on both chips.
3 more things to try to get this narrowed down...bear with me....
Try this out now:
'RECEIVE PIC
INCLUDE "modedefs.bas"
DEFINE OSC 20 'use external 20mhz crystal
CMCON = 7 : ANSEL = 0 : ADCON1 = 7
DEFINE LCD_DREG PORTA ' Set LCD Data port
DEFINE LCD_DBIT 0 ' Set starting Data bit (0 or 4) if 4-bit bus
DEFINE LCD_RSREG PORTB ' Set LCD Register Select port
DEFINE LCD_RSBIT 1 ' Set LCD Register Select bit
DEFINE LCD_EREG PORTB ' Set LCD Enable port
DEFINE LCD_EBIT 0 ' Set LCD Enable bit
DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits)
DEFINE LCD_LINES 2 ' Set number of lines on LCD
DEFINE LCD_COMMANDUS 2500
DEFINE LCD_DATAUS 250
'try1 = count of times waiting for data, try2 = count of bytes received
try1 var byte : try2 var byte : temp var word : tempf var word
temp1 var byte : temp2 var byte : temp3 var byte : temp4 var byte
input portb.2 : pause 2500
try1 = 0 : try2 = 0
loop:
lcdout $fe , $c0 , "Waiting.." , DEC3 try1 , "," , DEC3 try2
try1 = try1 + 1 : temp = 0 : tempf = 0
serin portB.2 , t2400 , [ temp1 , temp2 , temp3 , temp4 ]
temp.highbyte = temp1 : temp.lowbyte = temp2 : tempf.highbyte = temp3 : tempf.lowbyte = temp4
if temp + tempf > 0 then try2 = try2 + 1 'if temp+tempf are not 0 then data received
lcdout $fe , $c0 , "Received." , DEC3 try1 , "," , DEC3 try2 : pause 100
lcdout $fe , $c0 , "Display.." , DEC3 try1 , "," , DEC3 try2 : pause 100
lcdout $fe , $80 , "Tc=" , DEC3 temp , "C,Tf=" , DEC3 tempf , "FR" : pause 100
lcdout $fe , $c0 , "Shown...." , DEC3 try1 , "," , DEC3 try2 : pause 100
goto loop
'TRANSMIT PIC
DEFINE CHAR_PACING 16667
try1 var byte : try2 var byte : output portb.2 : input portb.3
dq var portb.4 : temp var word : tempf var word
pause 2500
try1 = 0 : try2 = 0
loop:
try1 = try1 + 1
lcdout $fe , $c0 , "Getting.." , DEC3 try1 , "," , DEC3 try2
owout DQ , 1 , [ $cc ] : owout DQ , 0 , [ $44 ] : Pause 500
owout DQ , 1 , [ $cc ] : owout DQ , 0 , [ $be ]
owin DQ , 0 , [ temp.LOWBYTE , temp.HIGHBYTE , skip 6 ]
tempf = temp * 9 : tempf = tempf / 5 : tempf = tempf + 32
tempf = 444 'hardcode transmitter to have 444 in tempf space
temp = 888 'hardcode transmitter to have 888 in temp space
lcdout $fe , $80 , "Tc=" , DEC3 temp , "C,Tf=" , DEC3 tempf , "FT"
lcdout $fe , $c0 , "Sending.." , DEC3 try1 , "," , DEC3 try2
temp1 = temp.highbyte : temp2 = temp.lowbyte
serout portb.2 , t2400 , [ temp1 , temp2 ]
temp3 = tempf.highbyte : temp4 = tempf.lowbyte
serout portb.2 , t2400 , [ temp3 , temp4 ]
try2 = try2 + 4 : lcdout $fe , $c0 , "Sent....." , DEC3 try1 , "," , DEC3 try2
goto loop
o, I wil wait a bit,
the receing LCD shows only on the second line, with zerosss.
