Serin serout problem
Results 1 to 40 of 337
    Sep 2006
    still no changes from previous. I just check the hardware, and seems to be ok, Cystal is oscillating at 20Mhz on both sides.
    Quote Originally Posted by lerameur View Post
    Could ya post another picture?
    Sep 2006
    actually I did, th e pic is back , i will do another one with the last circuit
    I just tried sending a constant over, and displaying it on the receiving end and it still gives me zero, maybe breaking the program into even more basic ?
    new PIC online
    with this last program, both counters are working on both chips.
    Did you make the changes in post #61?
    I saw the new picture. Let me think about this for a couple of minutes...
    Is the sending pic on the left or the right? Could you mark them with something...piece of masking tape on the transmitting pic or something?
    Sep 2006
    it updated now
    Sep 2006
    ok I am gpoing to bed now, see ya tomorrow
    it updated now
    3 more things to try to get this narrowed down...bear with me....
    Try this out now:
    'RECEIVE PIC
    INCLUDE "modedefs.bas"
    DEFINE OSC 20 'use external 20mhz crystal
    CMCON = 7 : ANSEL = 0 : ADCON1 = 7
    DEFINE LCD_DREG PORTA ' Set LCD Data port
    DEFINE LCD_DBIT 0 ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_RSREG PORTB ' Set LCD Register Select port
    DEFINE LCD_RSBIT 1 ' Set LCD Register Select bit
    DEFINE LCD_EREG PORTB ' Set LCD Enable port
    DEFINE LCD_EBIT 0 ' Set LCD Enable bit
    DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 2 ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2500
    DEFINE LCD_DATAUS 250
    'try1 = count of times waiting for data, try2 = count of bytes received
    try1 var byte : try2 var byte : temp var word : tempf var word
    temp1 var byte : temp2 var byte : temp3 var byte : temp4 var byte
    input portb.2 : pause 2500
    try1 = 0 : try2 = 0
    loop:
    lcdout $fe , $c0 , "Waiting.." , DEC3 try1 , "," , DEC3 try2
    try1 = try1 + 1 : temp = 0 : tempf = 0
    serin portB.2 , t2400 , [ temp1 , temp2 , temp3 , temp4 ]
    temp.highbyte = temp1 : temp.lowbyte = temp2 : tempf.highbyte = temp3 : tempf.lowbyte = temp4
    if temp + tempf > 0 then try2 = try2 + 1 'if temp+tempf are not 0 then data received
    lcdout $fe , $c0 , "Received." , DEC3 try1 , "," , DEC3 try2 : pause 100
    lcdout $fe , $c0 , "Display.." , DEC3 try1 , "," , DEC3 try2 : pause 100
    lcdout $fe , $80 , "Tc=" , DEC3 temp , "C,Tf=" , DEC3 tempf , "FR" : pause 100
    lcdout $fe , $c0 , "Shown...." , DEC3 try1 , "," , DEC3 try2 : pause 100
    goto loop
    'TRANSMIT PIC
    DEFINE CHAR_PACING 16667
    try1 var byte : try2 var byte : output portb.2 : input portb.3
    dq var portb.4 : temp var word : tempf var word
    pause 2500
    try1 = 0 : try2 = 0
    loop:
    try1 = try1 + 1
    lcdout $fe , $c0 , "Getting.." , DEC3 try1 , "," , DEC3 try2
    owout DQ , 1 , [ $cc ] : owout DQ , 0 , [ $44 ] : Pause 500
    owout DQ , 1 , [ $cc ] : owout DQ , 0 , [ $be ]
    owin DQ , 0 , [ temp.LOWBYTE , temp.HIGHBYTE , skip 6 ]
    tempf = temp * 9 : tempf = tempf / 5 : tempf = tempf + 32
    tempf = 444 'hardcode transmitter to have 444 in tempf space
    temp = 888 'hardcode transmitter to have 888 in temp space
    lcdout $fe , $80 , "Tc=" , DEC3 temp , "C,Tf=" , DEC3 tempf , "FT"
    lcdout $fe , $c0 , "Sending.." , DEC3 try1 , "," , DEC3 try2
    temp1 = temp.highbyte : temp2 = temp.lowbyte
    serout portb.2 , t2400 , [ temp1 , temp2 ]
    temp3 = tempf.highbyte : temp4 = tempf.lowbyte
    serout portb.2 , t2400 , [ temp3 , temp4 ]
    try2 = try2 + 4 : lcdout $fe , $c0 , "Sent....." , DEC3 try1 , "," , DEC3 try2
    goto loop
    Sep 2006
    o, I wil wait a bit,
    the receing LCD shows only on the second line, with zerosss.
    Last Post: - 8th March 2010, 20:58
  2. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 22:03
  3. serout and serin problem
    Last Post: - 11th April 2006, 19:44
  4. Replies: 11
    Last Post: - 13th July 2005, 19:26
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 15:54
