Serin serout problem
Results 1 to 40 of 337
    Quote Originally Posted by lerameur View Post
    I will leave is at n2400 then
    also, are you saying my pgd wire is messed up ??
    I am not sure what it is ? it is programming the sending side.., I am not sure what you meant
    The 100 ohm resistor did not do anything .
    Yes, try changing both sides to t2400 instead of n2400.
    You must be pulling the chips out and programming them. Changing the 'Waiting...' was just a quick way to make sure the PIC was actually being reprogrammed.
    I didn't expect the 100 ohm resistor to change anything, it's just a good idea from a 'safety' standpoint, saves PICs from blowing themselves up.
    And this is going to sound a bit wierd, but I'm wondering if SERIN and SEROUT don't like to deal with temp.highbyte and would rather deal with a byte value instead. Give me a couple of minutes to rewrite the programs and I'll post them in a couple of minutes.
    Sep 2006
    I didn't expect the 100 ohm resistor to change anything, it's just a good idea from a 'safety' standpoint, saves PICs from blowing themselves up.[/QUOTE]
    ok too much current, I get it
    no changes with t2400 on both chips
    Ok I changed the speed to 9600.
    I get the temperature showing on the receiving ship, but its showing zeros.
    also the increment try do not increment , But when i disconnect the wire, it increments every 0.5 sec
    'RECEIVE
    INCLUDE "modedefs.bas"
    DEFINE OSC 20 'use external 20mhz crystal
    CMCON = 7 : ANSEL = 0 : ADCON1 = 7
    DEFINE LCD_DREG PORTA ' Set LCD Data port
    DEFINE LCD_DBIT 0 ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_RSREG PORTB ' Set LCD Register Select port
    DEFINE LCD_RSBIT 1 ' Set LCD Register Select bit
    DEFINE LCD_EREG PORTB ' Set LCD Enable port
    DEFINE LCD_EBIT 0 ' Set LCD Enable bit
    DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 2 ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2500
    DEFINE LCD_DATAUS 250
    'try1 = count of times waiting for data, try2 = count of bytes received
    try1 var byte : try2 var byte : temp var word : tempf var word
    temp1 var byte : temp2 var byte : temp3 var byte : temp4 var byte
    input portb.2 : pause 2500
    try1 = 0 : try2 = 0
    loop:
    lcdout $fe , $c0 , "Waiting.." , DEC3 try1 , "," , DEC3 try2
    try1 = try1 + 1 : temp = 0 : tempf = 0
    serin portB.2 , t2400 , [ temp1 , temp2 , temp3 , temp4 ]
    temp.highbyte = temp1 : temp.lowbyte = temp2 : tempf.highbyte = temp3 : tempf.lowbyte = temp4
    if temp + tempf > 0 then try2 = try2 + 1 'if temp+tempf are not 0 then data received
    lcdout $fe , $c0 , "Received." , DEC3 try1 , "," , DEC3 try2 : pause 100
    lcdout $fe , $c0 , "Display.." , DEC3 try1 , "," , DEC3 try2 : pause 100
    lcdout $fe , $80 , "Tc=" , DEC3 temp , "C,Tf=" , DEC3 tempf , ".." : pause 100
    lcdout $fe , $c0 , "Shown...." , DEC3 try1 , "," , DEC3 try2 : pause 100
    goto loop
    'TRANSMIT
    DEFINE CHAR_PACING 16667
    try1 var byte : try2 var byte : output portb.2 : input portb.3
    dq var portb.4 : temp var word : tempf var word
    pause 2500
    try1 = 0 : try2 = 0
    loop:
    try1 = try1 + 1
    lcdout $fe , $c0 , "Getting.." , DEC3 try1 , "," , DEC3 try2
    owout DQ , 1 , [ $cc ] : owout DQ , 0 , [ $44 ] : Pause 500
    owout DQ , 1 , [ $cc ] : owout DQ , 0 , [ $be ]
    owin DQ , 0 , [ temp.LOWBYTE , temp.HIGHBYTE , skip 6 ]
    tempf = temp * 9 : tempf = tempf / 5 : tempf = tempf + 32
    lcdout $fe , $80 , "Tc=" , DEC3 temp , "C,Tf=" , DEC tempf , "F."
    lcdout $fe , $c0 , "Sending.." , DEC3 try1 , "," , DEC3 try2
    temp1 = temp.highbyte : temp2 = temp.lowbyte
    serout portb.2 , t2400 , [ temp1 , temp2 ]
    temp3 = tempf.highbyte : temp4 = tempf.lowbyte
    serout portb.2 , t2400 , [ temp3 , temp4 ]
    try2 = try2 + 4 : lcdout $fe , $c0 , "Sent....." , DEC3 try1 , "," , DEC3 try2
    goto loop
    If that works, then great. I don't know why it works. The PBP manual says the other way should work, but I seem to remember running into this problem before and had to do the same thing, I can't remember what I was doing though.
    Sep 2006
    sorry, still showing zeros at the receiving end, with nothing on the first line
    Then try this code for both TX and RX sides:
    'RECEIVE
    try1 = 0 : try2 = 0
    loop:
    temp1 = 3 : temp2 = 120 'hardcode receiver to display 888 in tempc space
    goto loop
    'TRANSMIT
    pause 2500
    try1 = 0 : try2 = 0
    loop:
    try1 = try1 + 1
    tempf = 444 'hardcode transmitter to have 444 in tempf space
    goto loop
    Sep 2006
    still no changes from previous. I just check the hardware, and seems to be ok, Cystal is oscillating at 20Mhz on both sides.
    Could ya post another picture?
    Sep 2006
    actually I did, th e pic is back , i will do another one with the last circuit
    I just tried sending a constant over, and displaying it on the receiving end and it still gives me zero, maybe breaking the program into even more basic ?
    new PIC online
    with this last program, both counters are working on both chips.
    Did you make the changes in post #61?
    I saw the new picture. Let me think about this for a couple of minutes...
    Is the sending pic on the left or the right? Could you mark them with something...piece of masking tape on the transmitting pic or something?
    Last Post: - 8th March 2010, 20:58
  2. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 22:03
  3. serout and serin problem
    Last Post: - 11th April 2006, 19:44
  4. Replies: 11
    Last Post: - 13th July 2005, 19:26
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 15:54
