Serin serout problem
Results 1 to 40 of 337
    Sep 2006
    ok, working now, Try2 was not initialized
    the sending counter works, but is about incrementing once every .5 seconds
    With temperature showing on the first line
    The second lcd (receiving) nothing on the first line , and the counter is not counting, The counter starts when the wire (input) is disconnected
    but NO Tc anf Tf
    k
    Quote Originally Posted by lerameur View Post
    but NO Tc anf Tf
    k
    Which PIC are you using?
    And while we're at it, try changing the receiving PIC receiving line over to portb.2 and change the references. Who knows...maybe you blew out a pin.
    Sep 2006
    I have not changed Pic16f88
    I also tried f84a, same thing
    I dont have much in the 6 series, more in the 18,
    Have you got PGM pulled low for your programmer?
    Sep 2006
    dont know, I am using this programmer:
    http://www.olimex.com/dev/pic-mcp-usb.html
    Move the serial input port on the receiver from RB3 to RB2 and change the program as required.
    Sep 2006
    nothing, i tried that before, acually I tried all the ports (B), same thing.
    k
    Last Post: - 8th March 2010, 20:58
  2. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 22:03
  3. serout and serin problem
    Last Post: - 11th April 2006, 19:44
  4. Replies: 11
    Last Post: - 13th July 2005, 19:26
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 15:54
