anywau here si the code fo the sending part:
i am just worried about the two serout line, should I put it into one line, or is it just the same like this,
I am leaving now, coming back ina few hours
'TRANSMIT PIC
INCLUDE "modedefs.bas"
DEFINE OSC 20 'use external 20mhz crystal
CMCON = 7 : ANSEL = 0 : ADCON1 = 7
DEFINE LCD_DREG PORTA ' Set LCD Data port
DEFINE LCD_DBIT 0 ' Set starting Data bit (0 or 4) if 4-bit bus
DEFINE LCD_RSREG PORTB ' Set LCD Register Select port
DEFINE LCD_RSBIT 1 ' Set LCD Register Select bit
DEFINE LCD_EREG PORTB ' Set LCD Enable port
DEFINE LCD_EBIT 0 ' Set LCD Enable bit
DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits)
DEFINE LCD_LINES 2 ' Set number of lines on LCD
DEFINE LCD_COMMANDUS 2500
DEFINE LCD_DATAUS 250
DEFINE CHAR_PACING 2000
DQ var PortB.5
temp var word
temperature var word
count_remain var byte
count_per_c var byte
counter var byte
encoded1 var word
encoded2 var word
encoded22 var word
encoded11 var word
encoded33 var word
encoded44 var word
loop:
owout DQ,1,[$cc]
owout DQ,0,[$44]
Pause 500
owout DQ,1,[$cc]
owout DQ,0,[$be]
owin DQ, 0, [temperature.LOwBYTE, temperature.Highbyte, Skip 4, count_remain, count_per_c]
'50
encoded1 =temperature.LowBYTE
encoded2 =temperature.HighBYTE
For counter=0 TO 7
IF encoded1.0[counter]=0 Then
encoded11.0[counter*2]=0
encoded11.0[counter*2+1]=1
Else
encoded11.0[counter*2]=1
encoded11.0[counter*2+1]=0
EndIF
Next counter
For counter=0 TO 7
IF encoded2.0[counter]=0 Then
encoded22.0[counter*2]=0
encoded22.0[counter*2+1]=1
Else
encoded22.0[counter*2]=1
encoded22.0[counter*2+1]=0
EndIF
Next counter
For counter=0 TO 7
IF count_remain.0[counter]=0 Then
encoded33.0[counter*2]=0
encoded33.0[counter*2+1]=1
Else
encoded33.0[counter*2]=1
encoded33.0[counter*2+1]=0
EndIF
Next counter
For counter=0 TO 7
IF count_per_c.0[counter]=0 Then
encoded44.0[counter*2]=0
encoded44.0[counter*2+1]=1
Else
encoded44.0[counter*2]=1
encoded44.0[counter*2+1]=0
EndIF
Next counter
lcdout $FE,1
LCDOUT "TempC: ", dec (temperature / 100) , ".", dec2 temperature," ",$DF,"C"
lcdout $FE,$C0, bin count_remain , ".", bin count_per_c," ",$DF,"F"
serout portb.2, n2400, [$55, $55, $55, $55, $aa]
serout portb.2, n2400, [encoded11.HighBYTE, encoded11.LowBYTE, encoded22.HighBYTE, encoded22.LowBYTE ]
serout portb.2, n2400, [encoded33.HighBYTE, encoded33.LowBYTE, encoded44.HighBYTE, encoded44.LowBYTE ]
goto loop
