Serin serout problem
Results 1 to 40 of 337
Threaded View
  1. #32
    Quote Originally Posted by lerameur View Post
    I will leave is at n2400 then
    also, are you saying my pgd wire is messed up ??
    I am not sure what it is ? it is programming the sending side.., I am not sure what you meant
    The 100 ohm resistor did not do anything .
    Yes, try changing both sides to t2400 instead of n2400.
    You must be pulling the chips out and programming them. Changing the 'Waiting...' was just a quick way to make sure the PIC was actually being reprogrammed.
    I didn't expect the 100 ohm resistor to change anything, it's just a good idea from a 'safety' standpoint, saves PICs from blowing themselves up.
    And this is going to sound a bit wierd, but I'm wondering if SERIN and SEROUT don't like to deal with temp.highbyte and would rather deal with a byte value instead. Give me a couple of minutes to rewrite the programs and I'll post them in a couple of minutes.
    Last Post: - 8th March 2010, 20:58
  2. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 22:03
  3. serout and serin problem
    Last Post: - 11th April 2006, 19:44
  4. Replies: 11
    Last Post: - 13th July 2005, 19:26
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 15:54
