'RECEIVE
INCLUDE "modedefs.bas"
DEFINE OSC 20 'use external 20mhz crystal
CMCON = 7 : ANSEL = 0 : ADCON1 = 7
DEFINE LCD_DREG PORTA ' Set LCD Data port
DEFINE LCD_DBIT 0 ' Set starting Data bit (0 or 4) if 4-bit bus
DEFINE LCD_RSREG PORTB ' Set LCD Register Select port
DEFINE LCD_RSBIT 1 ' Set LCD Register Select bit
DEFINE LCD_EREG PORTB ' Set LCD Enable port
DEFINE LCD_EBIT 0 ' Set LCD Enable bit
DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits)
DEFINE LCD_LINES 2 ' Set number of lines on LCD
'try1 = count of times waiting for data, try2 = count of bytes received
try1 var byte : try2 var byte : temp var word : tempf var word : input portb.2 : pause 2500
try1 = 0 : try2 = 0
loop:
lcdout $fe , $c0 , "Waiting.." , DEC3 try1 , "," , DEC3 try2
try1 = try1 + 1
serin portB.2 , n2400 , 1000 , loop , [ temp.highbyte , temp.lowbyte , tempf.highbyte , tempf.lowbyte ]
try2 = try2 + 4
lcdout $fe , $c0 , "Received." , DEC3 try1 , "," , DEC3 try2 : pause 100
lcdout $fe , $c0 , "Display.." , DEC3 try1 , "," , DEC3 try2 : pause 100
lcdout $fe , $80 , "Tc=" , DEC3 temp , "C,Tf=" , DEC3 tempf , ".." : pause 100
lcdout $fe , $c0 , "Shown...." , DEC3 try1 , "," , DEC3 try2 : pause 100
goto loop
'TRANSMIT
try1 var byte : try2 var byte : output portb.2 : input portb.3
dq var portb.4 : temp var word : tempf var word
pause 2500
try1 = 0 : try2 = 0
loop:
try1 = try1 + 1
lcdout $fe , $c0 , "Getting.." , DEC3 try1 , "," , DEC3 try2
owout DQ , 1 , [ $cc ] : owout DQ , 0 , [ $44 ] : Pause 500
owout DQ , 1 , [ $cc ] : owout DQ , 0 , [ $be ]
owin DQ , 0 , [ temp.LOWBYTE , temp.HIGHBYTE , skip 6 ]
tempf = temp * 9 : tempf = tempf / 5 : tempf = tempf + 32
lcdout $fe , $80 , "Tc=" , DEC3 temp , "C,Tf=" , DEC tempf , "F."
lcdout $fe , $c0 , "Sending.." , DEC3 try1 , "," , DEC3 try2
serout portb.2 , n2400 , [ temp.highbyte , temp.lowbyte ]
serout portb.2 , n2400 , [ tempf.highbyte , tempf.lowbyte ]
try2 = try2 + 4 : lcdout $fe , $c0 , "Sent....." , DEC3 try1 , "," , DEC3 try2
goto loop
Try those code chunks. I get the feeling that the lcd at the receiver end might have been overwriting itself, thereby blanking out the data or something. I also added a couple of pauses in there so you could see what was going on. Also, you didn't set the receiver port to an input (I know serin says it does this for you, but I never trust stuff like that).
