Serin serout problem
Results 1 to 40 of 337
Threaded View
  1. #33
    Quote Originally Posted by lerameur View Post
    I took a picture of both circuit
    receiving on the left
    http://www3.sympatico.ca/lerameur/
    its the exacte code you gave me :
    'RECEIVE
    INCLUDE "modedefs.bas"
    DEFINE OSC 20 'use external 20mhz crystal
    CMCON = 7 : ANSEL = 0 : ADCON1 = 7
    DEFINE LCD_DREG PORTA ' Set LCD Data port
    DEFINE LCD_DBIT 0 ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_RSREG PORTB ' Set LCD Register Select port
    DEFINE LCD_RSBIT 1 ' Set LCD Register Select bit
    DEFINE LCD_EREG PORTB ' Set LCD Enable port
    DEFINE LCD_EBIT 0 ' Set LCD Enable bit
    DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 2 ' Set number of lines on LCD
    'try1 = count of times waiting for bytes, try2 = count of bytes received
    try1 var byte : try2 var byte : temp var word : tempf var word : input portb.3 : pause 2500
    loop:
    lcdout $fe , $c0 , "Waiting..." , DEC3 try1 , "," , DEC3 try2
    try1 = try1 + 1
    serin portB.3 , n2400 , 1000 , loop , [ temp.highbyte , temp.lowbyte , tempf.highbyte , tempf.lowbyte ]
    try2 = try2 + 2
    lcdout $fe , $c0 , "Received.." , DEC3 try1 , "," , DEC3 try2
    lcdout $fe , $c0 , "Displaying" , DEC3 try1 , "," , DEC3 try2
    lcdout $fe , $80 , "Tc=" , DEC temp , "C,Tf=" , DEC tempf , ".."
    lcdout $fe , $c0 , "Displayed." , DEC3 try1 , "," , DEC3 try2
    goto loop
    The picture at the site is messed up. Scale it down or something.
    Have you tried switching the pins/code over to RB2?
    Have you tried changing the receiver to t2400?
    Change
    to
    serin portB.2 , n2400 , 100 , loop , [ temp.highbyte , temp.lowbyte , tempf.highbyte , tempf.lowbyte ]
    Now you should see try1 increment fast, like 10 times per second.
    Wait on it for a couple of minutes. If it only increases about once a minute or so, something is wrong with your oscillator, it's running on the internal backup failsafe oscillator.
    I thought you said DEC3 doesn't work?
    Last Post: - 8th March 2010, 21:58
  2. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 23:03
  3. serout and serin problem
    Last Post: - 11th April 2006, 20:44
  4. Replies: 11
    Last Post: - 13th July 2005, 20:26
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 16:54
