Serin serout problem - Page 4
Results 121 to 160 of 337
Threaded View
  1. #27
    Sep 2006
    its all good now, exept foe that part between 0 to -5 degrees celcius,
    There is no grey area, if the bit 11 os 1, then goto zerotemp, the math is the same for -1 C or -10C....
    'RECEIVE PIC
    INCLUDE "modedefs.bas"
    DEFINE OSC 20 'use external 20mhz crystal
    CMCON = 7 : ANSEL = 0 : ADCON1 = 7
    DEFINE LCD_DREG PORTA ' Set LCD Data port
    DEFINE LCD_DBIT 0 ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_RSREG PORTB ' Set LCD Register Select port
    DEFINE LCD_RSBIT 1 ' Set LCD Register Select bit
    DEFINE LCD_EREG PORTB ' Set LCD Enable port
    DEFINE LCD_EBIT 0 ' Set LCD Enable bit
    DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 2 ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2500
    DEFINE LCD_DATAUS 250
    DEFINE CHAR_PACING 2000
    counter var byte : temperature var word : encoded1 var word : encoded2 var word : encoded3 var byte
    encoded11 var word : encoded22 var word : encoded33 var word : encoded44 var word : encoded4 var byte
    count_remain var byte : count_per_c var byte : temp var word : tempc var byte : tempF var word
    temperature1 var word
    pause 2000
    loop:
    '23
    waitfor55:
    serin portb.2 , n2400 , temp : if temp <> $55 then goto waitfor55
    waitforaa:
    serin portb.2 , n2400 , temp : if temp <> $aa then goto waitforaa
    serin portb.2, n2400, encoded11.HighBYTE : serin portb.2, n2400, encoded11.LowBYTE
    serin portb.2, n2400, encoded22.HighBYTE : serin portb.2, n2400, encoded22.LowBYTE
    serin portb.2, n2400, encoded33.HighBYTE : serin portb.2, n2400, encoded33.LowBYTE
    serin portb.2, n2400, encoded44.HighBYTE : serin portb.2, n2400, encoded44.LowBYTE
    For counter=0 TO 7 'decoding
    encoded1.0[counter]=encoded11.0[counter*2] : encoded2.0[counter]=encoded22.0[counter*2]
    encoded3.0[counter]=encoded33.0[counter*2] : encoded4.0[counter]=encoded44.0[counter*2]
    Next counter
    '41
    temperature= encoded1 ' putting back together as the original temperature
    For counter=0 TO 7
    temperature.0[counter+8]=encoded2.0[counter+8]
    Next counter
    temperature.LowBYTE = encoded1
    temperature.HighBYTE = encoded2
    count_remain = encoded3
    count_per_c = encoded4
    IF temperature.11 = 1 Then goto Zerotemp
    temperature = ((( temperature >> 1) *100)- 25) + (((count_per_c - count_remain) * 100) / count_per_c)
    tempF = (((temperature /5) *9 ) + 3200)
    lcdout $FE,1, "TempC: ", "+", dec (temperature / 100) , ".", dec2 temperature," ",$DF,"C"
    lcdout $FE,$C0, "TempF: ", "+", dec2 (tempF / 100) , ".", dec2 (tempF // 100)," ",$DF,"F"
    goto loop
    Zerotemp: ' cases when zero celcius and positive Fahrenheit
    temperature = temperature >> 1 'removing lowest bit
    temperature1 = temperature
    for counter = 0 to 6
    if temperature.0[counter] = 1 then
    temperature.0[counter] = 0
    next counter
    temp = temp + 1 ' 2,s compliment ends by adding a one
    temp = temp >> 5
    temperature = ((( temp ) *100)- 25) + (((count_per_c - count_remain) * 100) / count_per_c)
    tempF = 3200 -((temperature /5) * 9)
    if tempF = 0 then goto ZeroF
    lcdout $FE,1, "TempC: ", "-", dec (temperature / 100) , ".", dec2 temperature," ",$DF,"C"
    lcdout $FE,$C0, "TempF: ", dec (tempF / 100) , ".", dec2 tempF ," ",$DF,"F"
    goto loop
    ZeroF: ' cases when zero celcius and 0 Fahrenheit
    lcdout $FE,$C0, "TempF: ", "-", dec (tempF / 100) , ".", dec2 tempF ," ",$DF,"F"
    goto loop
    Last Post: - 8th March 2010, 21:58
  2. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 23:03
  3. serout and serin problem
    Last Post: - 11th April 2006, 20:44
  4. Replies: 11
    Last Post: - 13th July 2005, 20:26
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 16:54
