Serin serout problem
Results 1 to 40 of 337
    Sep 2006
    well same results with n2400 and t2400
    Quote Originally Posted by lerameur View Post
    And you're using the program as listed in post #118?
    Probably going to end up backing up again, so we can move forward again!
    Sep 2006
    ok eee, seems to be working now, am I awake....
    thank you thank you
    i will try the wireless
    what is this line for (was for , or intended to)
    'templo = converts[templo] : temphi = converts[temphi]
    thank you thank you
    Well, what program are you running right now? I changed some stuff and was about to post it...but if you say it's working correctly at both ends, then I'll go with that.... So, repost the program you're running now (if it works), so I can remember what the line above did.
    Sep 2006
    using post 118
    it works wireless,
    does it have to do with the encoding technique ?
    but most often its showing good temp.
    Sep 2006
    could I add a 10v voltage regulator for the RF transmitter to boost up the signal ? I am using the rentron 433mhz chips tws
    If you're running the module at 5v now, you're good for about 500ft (that's what I've gotten at 9600 a few times, a few errors, but it still worked). and if you read the datasheet, you'll see that you have to run your data input line to the TX module at the same voltage range as your power input.
    I've ran that TX module at 2.5v before and gotten 100ft without troubles.
    using post 118
    it works wireless, I get a lot glitches meaning temperature showing weird numbers like 930 , 445, etc.. it stays at those odd numbers for 3-5 seconds sometimes,
    Glitches - Probably has to do with the encoding technique because the data isn't encoded (I commented that part out in post #118), but the 'training' bytes are encoded.
    Maybe try to add a few more $55 to the serout line in the transmit section. And make sure the char_pacing isn't in the define sections anymore.
    Sep 2006
    I di dwhat you told me removing the char_spac adding more $55, its worst now,
    its constantly showing 360, 445, and sometime the temperature
    more often 445
    Last Post: - 8th March 2010, 20:58
  2. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 22:03
  3. serout and serin problem
    Last Post: - 11th April 2006, 19:44
  4. Replies: 11
    Last Post: - 13th July 2005, 19:26
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 15:54
