Serin serout problem
Results 1 to 40 of 337
    Sep 2006
    no changes,
    ok i will try the wireless
    Quote Originally Posted by lerameur View Post
    no changes,
    I meant changing the t2400 to n2400, not switching over to wireless yet. Still have to get the comm's working without the wireless.
    How about this... (getting annoying isn't it? )
    I commented out the encoding/decoding parts. Just sending a split up raw value now....see what happens...
    'RECEIVE PIC
    'same includes and defines as the other versions
    temp var word : tempf var word : counter var byte : templo var byte
    temphi var byte : input portb.2 : converts var byte[15] : convtemp var byte
    converts[0] = $55 : converts[1] = $56 : converts[2] = $59
    converts[3] = $5a : converts[4] = $65 : converts[5] = $66
    converts[6] = $69 : converts[7] = $6a : converts[8] = $95
    converts[9] = $96 : converts[10] = $99 : converts[11] = $9a
    converts[12] = $a5 : converts[13] = $a6 : converts[14] = $a9
    converts[15] = $aa : pause 1000
    loop:
    counter = counter + 1 : lcdout $fe , $c0 , "Waiting......" , DEC3 counter
    waitfor55:
    serin portb.2 , n2400 , temp : if temp <> $55 then goto waitfor55
    waitforaa:
    serin portb.2 , n2400 , temp : if temp <> $aa then goto waitforaa
    serin portb.2 , n2400 , templo : serin portb.2 , n2400 , temphi
    'for convtemp = 0 to 15
    'if templo = converts[temp] then templo = convtemp
    'if temphi = converts[temp] then temphi = convtemp
    'next convtemp
    temp = ( temphi << 4 ) + templo : tempf = temp * 9 : tempf = tempf / 5
    tempf = tempf + 32
    lcdout $fe , $80 , "Tc=" , DEC3 temp , "C,Tf=" , DEC3 tempf , "F."
    lcdout $fe , $c0 , "Received....." , DEC3 count
    goto loop
    'TRANSMIT PIC
    'remove the char_pacing value, with it in there, the RX will lose it's "training"
    counter var byte : temp var word : output portb.2 : high portb.2
    input portb.3 : dq var portb.4 : templo var byte : temphi var byte
    converts var byte[15] : converts[0] = $55 : converts[1] = $56
    converts[2] = $59 : converts[3] = $5a : converts[4] = $65
    converts[5] = $66 : converts[6] = $69 : converts[7] = $6a
    converts[8] = $95 : converts[9] = $96 : converts[10] = $99
    converts[11] = $9a : converts[12] = $a5 : converts[13] = $a6
    converts[14] = $a9 : converts[15] = $aa : pause 1000
    loop:
    lcdout $fe , $c0 , "Getting......" , DEC3 count : owout DQ , 1 , [ $cc ]
    owout DQ , 0 , [ $44 ] : Pause 500 : owout DQ , 1 , [ $cc ]
    owout DQ , 0 , [ $be ]
    owin DQ , 0 , [ temp.LOWBYTE , temp.HIGHBYTE , skip 6 ]
    lcdout $fe , $c0 , "Sending......" , DEC3 count
    templo = temp.lowbyte & $f : temphi = temp.lowbyte >> 4
    'templo = converts[templo] : temphi = converts[temphi]
    serout portb.2 , n2400 , [ $55 , $55 , $55 , $55 , $aa ]
    serout portb.2 , n2400 , [ templo , temphi ]
    goto loop
    Sep 2006
    well same results with n2400 and t2400
    And you're using the program as listed in post #118?
    Probably going to end up backing up again, so we can move forward again!
    Sep 2006
    ok eee, seems to be working now, am I awake....
    thank you thank you
    what is this line for (was for , or intended to)
    thank you thank you
    Well, what program are you running right now? I changed some stuff and was about to post it...but if you say it's working correctly at both ends, then I'll go with that.... So, repost the program you're running now (if it works), so I can remember what the line above did.
    Sep 2006
    using post 118
    it works wireless,
    does it have to do with the encoding technique ?
    but most often its showing good temp.
    Last Post: - 8th March 2010, 20:58
  2. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 22:03
  3. serout and serin problem
    Last Post: - 11th April 2006, 19:44
  4. Replies: 11
    Last Post: - 13th July 2005, 19:26
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 15:54
