Serin serout problem
Results 1 to 40 of 337
    Sep 2006
    HI, NO I have not found the problem . I was about to order some pic16f648a, you told it worked with these chips.
    I tried your program , the No sync appears at every increment,
    so guess there is a problem with the trailer or leader bit.
    k
    Quote Originally Posted by lerameur View Post
    k
    I wouldn't order any '648's or '628's, the 'F88 should be just fine.
    What does the display read? Does it show the hardcoded 444 and 888? Did you try removing that? Also, get rid of the pauses in the receiver code, or at least drop them down a bit, cut them in half or so.
    JUST SAW THIS: In the transmit code, the trailer byte should be a $55, not $ff. That'll probably fix it now. The fact that you said it shows 'No Sync' at 'EVERY INCREMENT' is the key thing, it shows that the loop is going thru the SERIN commands now.
    Last edited by skimask; - 26th December 2006 at 19:18. Reason: fixing mistake in the transmitter side
    Sep 2006
    The display never showed the 444 or 888.
    I posted a new picture.
    I tried removing the pauses, putting them at half the pause you had them, also changed the trailer byte to $55 ..same effect.
    Ok, let's try the silly simple and build back up... I guess we gotta figure out where this whole thing is failing at. If this don't work......I dunno....
    'RECEIVE PIC
    INCLUDE "modedefs.bas"
    DEFINE OSC 20 'use external 20mhz crystal
    CMCON = 7 : ANSEL = 0 : ADCON1 = 7
    DEFINE LCD_DREG PORTA ' Set LCD Data port
    DEFINE LCD_DBIT 0 ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_RSREG PORTB ' Set LCD Register Select port
    DEFINE LCD_RSBIT 1 ' Set LCD Register Select bit
    DEFINE LCD_EREG PORTB ' Set LCD Enable port
    DEFINE LCD_EBIT 0 ' Set LCD Enable bit
    DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 2 ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2500
    DEFINE LCD_DATAUS 250
    temp var word : temp1 var word : input portb.2
    loop:
    serin portb.2 , t2400 , [ temp ]
    lcdout $fe , $80 , DEC3 temp
    temp1 = temp1 + 1
    lcdout $fe , $c0 , DEC5 temp1
    goto loop
    'TRANSMIT PIC
    DEFINE CHAR_PACING 33333
    temp var byte : temp1 var word : output portb.2
    loop:
    temp = temp + 1
    serout portb.2 , t2400 , [ temp ]
    temp1 = temp1 + 1
    goto loop
    Sep 2006
    ok, the sending pic increment both on line 1 and two
    the receiving end displays a constant 535 on the 1st line and 49102 on the second line
    problem still persist
    Sep 2006
    ok here it is :
    THIS DO NOT WORK;
    loop:
    serin portb.2 , n2400 , [ temp]
    lcdout $fe , $80 , DEC temp
    pause 200
    goto loop
    THIS WORKS;;
    loop:
    serin portb.2 , n2400 , temp
    pause 200
    goto loop
    AS soon as I put the square brackt , the display is messed up
    ok here it is :
    THIS DO NOT WORK;
    loop:
    pause 200
    goto loop
    THIS WORKS;;
    loop:
    pause 200
    goto loop
    You are abso-freekin-lutely right!!!!!!!!!! My fonts have been messed up this whole time on my pdf viewer!!!!!!!! In the PBP manual, it shows what looks like brackets around the 'item', when there really isn't any brackets!!!!!!! AND...when I looked at the project I was saying that worked just fine, it doesn't have brackets either!!!!!!! Freekin''''amazing....I should've caught this days ago!!!!!
    Let's go back, but not as far...
    Working on another post/program that should work 100% all the way this time.
    (damn, I could seriously kick my own ass right now)....
    I'll have it posted here in a few minutes...
    Last Post: - 8th March 2010, 20:58
  2. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 22:03
  3. serout and serin problem
    Last Post: - 11th April 2006, 19:44
  4. Replies: 11
    Last Post: - 13th July 2005, 19:26
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 15:54
