Serin serout problem
Results 1 to 40 of 337
    Sep 2006
    like on the picture, its 2 pics
    i tried this thing but it do not work
    loop:
    lcdout $fe , $c0 , "Waiting.." , DEC3 try1 , "," , DEC3 try2
    try1 = try1 + 1 : temp = 0 : tempf = 0
    serin portB.2 , t2400 , [ temp1 , temp2 , temp3 , temp4 ]
    if temp1 > temp2 then
    Portb.4 =1 ------------putting a led here, maybe lcdout is confusing with serin
    portb.4=0
    Portb.3 =1 -----------putting a led here
    portb.3=0
    goto loop
    Sep 2006
    Ok I am really going now to sleep, see ya later
    Quote Originally Posted by lerameur View Post
    loop:
    portb.4=0
    portb.3=0
    goto loop
    I meant are you putting the transmit code into the transmit PIC and the receive code into the receive PIC, not the whole thing into both PICs...
    Sep 2006
    'TRANSMIT PIC = one pic
    'RECEIVE PIC = another pic
    dont worry, only the part that belongs there
    Ok, just checking because in that one picture it looked like both PICs had the same writing on them.
    Now try this code:
    'RECEIVE PIC
    INCLUDE "modedefs.bas"
    DEFINE OSC 20 'use external 20mhz crystal
    CMCON = 7 : ANSEL = 0 : ADCON1 = 7
    DEFINE LCD_DREG PORTA ' Set LCD Data port
    DEFINE LCD_DBIT 0 ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_RSREG PORTB ' Set LCD Register Select port
    DEFINE LCD_RSBIT 1 ' Set LCD Register Select bit
    DEFINE LCD_EREG PORTB ' Set LCD Enable port
    DEFINE LCD_EBIT 0 ' Set LCD Enable bit
    DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 2 ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2500
    DEFINE LCD_DATAUS 250
    'try1 = count of times waiting for data, try2 = count of bytes received
    try1 var byte : try2 var byte : temp var word : tempf var word
    temp1 var byte : temp2 var byte : temp3 var byte : temp4 var byte
    input portb.2 : pause 2500
    try1 = 0 : try2 = 0
    loop:
    temp.highbyte = temp1 : temp.lowbyte = temp2 : tempf.highbyte = temp3 : tempf.lowbyte = temp4
    if temp + tempf > 0 then try2 = try2 + 1 'if temp+tempf are not 0 then data received
    lcdout $fe , $c0 , "Received." , DEC3 try1 , "," , DEC3 try2 : pause 100
    lcdout $fe , $c0 , "Display.." , DEC3 try1 , "," , DEC3 try2 : pause 100
    lcdout $fe , $80 , "Tc=" , DEC3 temp , "C,Tf=" , DEC3 tempf , "FR" : pause 100
    lcdout $fe , $c0 , "Shown...." , DEC3 try1 , "," , DEC3 try2 : pause 100
    goto loop
    'TRANSMIT PIC
    DEFINE CHAR_PACING 16667
    try1 var byte : try2 var byte : output portb.2 : input portb.3
    dq var portb.4 : temp var word : tempf var word
    pause 2500
    try1 = 0 : try2 = 0
    loop:
    try1 = try1 + 1
    lcdout $fe , $c0 , "Getting.." , DEC3 try1 , "," , DEC3 try2
    owout DQ , 1 , [ $cc ] : owout DQ , 0 , [ $44 ] : Pause 500
    owout DQ , 1 , [ $cc ] : owout DQ , 0 , [ $be ]
    owin DQ , 0 , [ temp.LOWBYTE , temp.HIGHBYTE , skip 6 ]
    tempf = temp * 9 : tempf = tempf / 5 : tempf = tempf + 32
    tempf = 444 'hardcode transmitter to have 444 in tempf space
    temp = 888 'hardcode transmitter to have 888 in temp space
    lcdout $fe , $80 , "Tc=" , DEC3 temp , "C,Tf=" , DEC3 tempf , "FT"
    lcdout $fe , $c0 , "Sending.." , DEC3 try1 , "," , DEC3 try2
    temp1 = temp.highbyte : temp2 = temp.lowbyte
    serout portb.2 , t2400 , [ temp1 , temp2 ]
    temp3 = tempf.highbyte : temp4 = tempf.lowbyte
    serout portb.2 , t2400 , [ temp3 , temp4 ]
    try2 = try2 + 4 : lcdout $fe , $c0 , "Sent....." , DEC3 try1 , "," , DEC3 try2
    goto loop
    And post a fresh picture if you can
    Sep 2006
    ok , I'm back, still no changes,
    picture up
    The two leds there are from a previous program which instead of using lcdout, I was trying to make led blink.
    but the picture was takien while your last program was working
    Sep 2006
    i tried this program for the reciver. The led blinks, If I added the serin , led would sit on high. There is definately a problem with serin command, It does not work with lcdout or simple led blinking
    'RECEIVE PIC
    try1 = 0 : try2 = 0
    trisb=%00000000
    loop:
    'serin portB.2 , t2400 , [ temp1 , temp2 , temp3 , temp4 ]
    Portb.4 =1 : pause 500 : portb.4=0
    Portb.3 =1 : pause 500 : portb.3=0
    goto loop
    I also wanted to see if the chip was able to see the data coming in, so i tried this loop, and nothing is happening to the led:
    loop:
    if temp1 > 0 then
    goto loop
    Sep 2006
    Ok now I used your pogram and changed the serin line :
    serin portB.2 , t2400 , temp1 -----works
    It takes in the value,IT is NOW working. BUT For some odd reason it do not take multiple input..
    serin portB.2 , t2400 , [ temp1 , temp2 , temp3 , temp4 ] ------------- do not work
    Last Post: - 8th March 2010, 20:58
  2. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 22:03
  3. serout and serin problem
    Last Post: - 11th April 2006, 19:44
  4. Replies: 11
    Last Post: - 13th July 2005, 19:26
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 15:54
