Running an LCD on different port
Results 1 to 8 of 8
    Usually i place all LCD DEFINE's at the top even if i use the default pin assignement. It's easier to change later.
    DEFINE LCD_DREG PORTC     ' LCD data port
    DEFINE LCD_DBIT 0         ' LCD data starting bit 0 or 4
    DEFINE LCD_RSREG PORTC    ' LCD register select port
    DEFINE LCD_RSBIT 4        ' LCD register select bit
    DEFINE LCD_EREG PORTC     ' LCD enable port
    DEFINE LCD_EBIT 5         ' LCD enable bit
    DEFINE LCD_BITS 4         ' LCD bus size 4 or 8
    DEFINE LCD_LINES 2        ' Number lines on LCD
    DEFINE LCD_COMMANDUS 2000 ' Command delay time in us
    DEFINE LCD_DATAUS 50      ' Data delay time in us
    You don't need to disable the USART as he's already disable at POR.
    malc-c's Avatar
    malc-c Guest
    Thanks steve, that make a lot of sence (Cuts and pastes code in readyness )
    Jun 2005
    Penang
    Unhappy Problem Displaying dunno why?
    I got some problem with displaying 20 X 4 line LCD which the controller chip is HD 44780.Actually,when i programmed the chip according to the code below,the lcd is not working!.I even checked the PORTB pin and it seems not changing state?.But my board is working as i checked other programs (I2C,SPI) but this one is not working?.I feel weird.This program is actually sample program from Melabs itself.I wired the final 4 bit from lcd to PORTB.0 to PORTB.3 and the EBIT to to PORTD.7 and for sure RSBIT to PORTD.6.
    What is my mistake??Do i have to insert more code like LCD lines and delay???PLS HELP!
    DEFINE OSC 20
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 4 ' 4 bit selected
    DEFINE LCD_RSREG PORTD
    DEFINE LCD_RSBIT 6 ' Reset Pin
    DEFINE LCD_EREG PORTD
    DEFINE LCD_EBIT 7 ' Enable Pin
    pause 500 ' Insert Delay for LCD to Power_Up.
    loop:
    Lcdout $fe, 1 ' Clear LCD screen
    Lcdout "Hello" ' Display Hello
    Pause 500 ' Wait .5 second
    Lcdout "World"
    Goto loop ' Do it forever
    YOUR HELP KINDLY ACCEPTED
    Change this
    to
    DEFINE LCD_DBIT 0 ' Databit start at PORTB.0
    Jun 2005
    Penang
    Thumbs down I tried...
    Thanks for Instant reply but...
    Although i have changed the bit size from 4 to 0,it still remains the same.It does nothing.I even switch compiling from MPASM to standard compiler and it didn't show any effect at all.All the display line shows blank.
    It's a cheap LCD ( LM044L) and it's buggin me a lot.I still wonder why the PIC never do anything.I had no problem compiling other program but not this one.
    Any idea?.Pls help.Thanks a lot mister_e
    Make sure the R/W pin is set to GND & play with the contrast Pot
    What happen?
    What is your PIC #?
    Could be the the config fuses as well, make sure you set HS_OSC and LVP_OFF
    Did you tied your unused LCD data pin (DB0, DB1, DB2, DB3) to gnd?
    And it's suppose to be a 4X20 LCD type.. you may try to add
    DEFINE LCD_LINES 4
    Jun 2005
    Penang
    Question Gonna give a try..
    I never tie the unused pin to ground as i belive it can be left floating?.Anyhow i will do it.I use PIC16F877.HS_OSC is set .I always set LVP_OFF (Low Voltage Programming) as it always does.Ok.I will insert : DEFINE LCD_LINES 4 :and see what happens.Not today but for sure tomorrow.
    Thanks a lot Steve.You are great.Hope you can help me tommorow too =>.
    NatureTech.
    Make thing simple,but not simpler.
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 19:14
  3. LCD R/S works on Port A but not Port B
    By TDonBass in forum mel PIC BASIC Pro
    Last Post: - 10th February 2009, 12:41
  5. Microcontroller with 2 way paging application problem
