Running an LCD on different port
Results 1 to 8 of 8
    malc-c's Avatar
    malc-c Guest
    Default Running an LCD on different port
    Quick question..(hopefully)
    In the PBP manual it details the use of PortB to interface with a 2 x 16 LCD.
    PBP assumes the LCD is connected to specific pins unless told otherwise. It assumes the LCD will be used with a 4-bit bus with data lines DB4 - DB7 connected to PICmicro PORTA.0 - PORTA.3, Register Select to PORTA.4 and Enable to PORTB.3.
    It is also preset to initialize the LCD to a 2 line display.
    To change this setup, place one or more of the following DEFINEs, all in upper-case, at the top of your PICBASIC PRO™ program:
    ' Set LCD Data port
    DEFINE LCD_DREG PORTB
    ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_DBIT 4
    ' Set LCD Register Select port
    DEFINE LCD_RSREG PORTB
    If I wanted to use PORTC for the LCD display on a 16F873A PIC would the following work if the wiring was the same as shown in the manual (obviously substituting RA1 for RC1 etc)?
    ' Set LCD Data port
    DEFINE LCD_DREG PORTC
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTC
    is there anything eles I would need to do to configure PORTC on the PIC other than TRISC=%00000000, for arguments sake disabling the rx / tx on ports RC7 and 6 ?
    Usually i place all LCD DEFINE's at the top even if i use the default pin assignement. It's easier to change later.
    DEFINE LCD_DREG PORTC     ' LCD data port
    DEFINE LCD_DBIT 0         ' LCD data starting bit 0 or 4
    DEFINE LCD_RSREG PORTC    ' LCD register select port
    DEFINE LCD_RSBIT 4        ' LCD register select bit
    DEFINE LCD_EREG PORTC     ' LCD enable port
    DEFINE LCD_EBIT 5         ' LCD enable bit
    DEFINE LCD_BITS 4         ' LCD bus size 4 or 8
    DEFINE LCD_LINES 2        ' Number lines on LCD
    DEFINE LCD_COMMANDUS 2000 ' Command delay time in us
    DEFINE LCD_DATAUS 50      ' Data delay time in us
    You don't need to disable the USART as he's already disable at POR.
    malc-c's Avatar
    malc-c Guest
    Thanks steve, that make a lot of sence (Cuts and pastes code in readyness )
    Jun 2005
    Penang
    Unhappy Problem Displaying dunno why?
    I got some problem with displaying 20 X 4 line LCD which the controller chip is HD 44780.Actually,when i programmed the chip according to the code below,the lcd is not working!.I even checked the PORTB pin and it seems not changing state?.But my board is working as i checked other programs (I2C,SPI) but this one is not working?.I feel weird.This program is actually sample program from Melabs itself.I wired the final 4 bit from lcd to PORTB.0 to PORTB.3 and the EBIT to to PORTD.7 and for sure RSBIT to PORTD.6.
    What is my mistake??Do i have to insert more code like LCD lines and delay???PLS HELP!
    DEFINE OSC 20
    DEFINE LCD_DBIT 4 ' 4 bit selected
    DEFINE LCD_RSREG PORTD
    DEFINE LCD_RSBIT 6 ' Reset Pin
    DEFINE LCD_EREG PORTD
    DEFINE LCD_EBIT 7 ' Enable Pin
    pause 500 ' Insert Delay for LCD to Power_Up.
    loop:
    Lcdout $fe, 1 ' Clear LCD screen
    Lcdout "Hello" ' Display Hello
    Pause 500 ' Wait .5 second
    Lcdout "World"
    Goto loop ' Do it forever
    YOUR HELP KINDLY ACCEPTED
    Change this
    to
    DEFINE LCD_DBIT 0 ' Databit start at PORTB.0
    Jun 2005
    Penang
    Thumbs down I tried...
    Thanks for Instant reply but...
    Although i have changed the bit size from 4 to 0,it still remains the same.It does nothing.I even switch compiling from MPASM to standard compiler and it didn't show any effect at all.All the display line shows blank.
    It's a cheap LCD ( LM044L) and it's buggin me a lot.I still wonder why the PIC never do anything.I had no problem compiling other program but not this one.
    Any idea?.Pls help.Thanks a lot mister_e
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 19:14
  3. LCD R/S works on Port A but not Port B
    By TDonBass in forum mel PIC BASIC Pro
    Last Post: - 10th February 2009, 12:41
  5. Microcontroller with 2 way paging application problem
