TMR1 How it works?
Results 1 to 9 of 9
Threaded View
  1. #2
    read the section 4.0 of the OlympicTimer document
    http://www.picbasic.co.uk/forum/atta...4&d=1091819883
    RunningFlag variable start and stop the timer.. at least the increment of. Look at the TickCount section.
    Yes you should be able to Store the TMR1 result at any time without too much effect. But the results you need are not store there. See ...
    LCDOut $FE,$80,DEC2 Hours,":",DEC2 Minutes,":",DEC2 Seconds,".",DEC2 Hundredths
  1. Simple TMR1 application example needed
    Last Post: - 4th February 2010, 09:52
  2. TMR1 external LP xtal setup check
    By comwarrior in forum mel PIC BASIC Pro
    Last Post: - 13th October 2009, 18:11
  3. Replies: 2
    Last Post: - 7th October 2009, 00:06
  4. Replies: 42
    Last Post: - 14th January 2008, 11:38
  5. Measuring change of frequency with PIC
    By Aussie in forum mel PIC BASIC Pro
    Last Post: - 19th July 2007, 01:47
