If you want to use RB0 for the input, then use it, change the lines in the code. The schmidt trigger input will help to clean up a noisy signal a little bit, but I don't know if I'd go so far as to start messing with different pins and methods of reading the pulses until you've tried it in the car. I know the signals would be dirty being in an automotive environment...but... The injectors won't be firing at more than (give or take) 5,000/sec (10,000 rpm). So why not a simple opamp before the PIC with a 5khz rolloff or an even simpler R/C filter? Play with it and see what happens... that's the only way you'll figure out how much filtering you may or may not need.
