How can I measure Duty cycle ?
Results 1 to 21 of 21
    Quote Originally Posted by MaxiBoost View Post
    @Skimask ,
    yess its work ,thank your interesting .
    Its not bad ,so close result with duty cycle meter.
    I can use it on my car .
    Some problem I have ,
    1-why I see on the lcd "35" %100 duty cycle ?
    2-People use RB0 input "schmit trigger" on duty cycle meter .
    How can use schmit trigger input my circuit ?
    1 - 100% (and 0%) duty cycle is a special case...100% pulshi and 0% pulslo. Put in a test to see if either pulshi or pulslo is 0 and handle it as required.
    2 - why mess with it if it works?
    Quite frankly, I'm surprise it worked that well for a first try, and that code was off the top of my head.
    And your pictures were practically useless. Either backlight the LCD or turn on some lights!
    Nov 2006
    ist
    @skimask ,
    I`ll take this picture only for you
    Schmit trigger ;
    Because I`m work on the table at home ,not on car ,
    and use a 555 for signal not car enjector`s signal .
    Im sure cars injector signal or ecu` injector out signal is Not clean ..
    Thank you again.
    @skimask ,
    Schmit trigger ;
    Thank you again.
    If you want to use RB0 for the input, then use it, change the lines in the code. The schmidt trigger input will help to clean up a noisy signal a little bit, but I don't know if I'd go so far as to start messing with different pins and methods of reading the pulses until you've tried it in the car. I know the signals would be dirty being in an automotive environment...but... The injectors won't be firing at more than (give or take) 5,000/sec (10,000 rpm). So why not a simple opamp before the PIC with a 5khz rolloff or an even simpler R/C filter? Play with it and see what happens... that's the only way you'll figure out how much filtering you may or may not need.
  1. Replies: 9
    Last Post: - 8th October 2008, 12:15
  2. how to generate 83.33khz with 16.7% duty cycle?
    By donatelo in forum mel PIC BASIC Pro
    Last Post: - 23rd September 2008, 18:08
  3. HPWM the old fashioned way
    By Srigopal007 in forum mel PIC BASIC Pro
    Last Post: - 19th November 2004, 20:09
  4. PWM _ Duty Cycle in Tenths
    By rwskinner in forum mel PIC BASIC Pro
    Last Post: - 17th May 2004, 13:09
  5. Duty Cycle Dilemmas
    By crankshaft in forum mel PIC BASIC Pro
    Last Post: - 27th February 2003, 13:40
