Changing Settings ???
Results 1 to 5 of 5
    Quote Originally Posted by tico View Post
    What I would like to do is use a few switches and/or a serial port to change the setting of the thermostat ie. Mode Summer/Winter, High Set Point, Low Setpoint and cant seem to find any code samples.
    How do you store settings in a PIC and use a switch input to change those settings.
    Hi,Tico
    First you'll have to choose how to "poll" the request for changes ...
    Interrupts looks the easiest way , as interrupts on port change, and interrupt on USART receive already exist aboard your PIC !!!
    Then, just decide which coding you'll choose for the differents parameters ( serial input ) , and which menu you'll write for button programming ... looks a LCD could be useful here ...
    After that, when the "valid" switch pushed or serial code will be received, just write parameters to their respective EEPROM locations ...
    Dec 2006
    Thanks b1arrk5
    I started feeling left out and thought that maybe I asked a question with an obvious answer, I did scour the forum and found a post about a clock that used switches to set the time, I am using that code by Melanie as my basis for the input, of course I am trying to find that post now for reference and cant find it, I believe I still have an excess of eggnog floating around also.
    I did find the file on my pc though it is mn1307.bas
    Would I be correct to say that I could just add the SEROUT2 command everwhere it has an LCDOUT command and vice versa with the input switch use a SERIN2 command.
    I pasted a section of code below to show what I mean
    SetupLoop:
    LCDOut $FE,1,"Set "
    SEROUT2 "Set"
    ' First Display the Menu Prompts
    ' This is a crude way of doing the entry Menu's but it was
    ' pretty fast and quite mindless to program this lunch-hour
    If CounterC=0 then
    LCDOut "Mode"
    SEROUT2 "Mode"
    I am hoping that this method will work.....
    Thanks for the suggestion for set point variable being between 55 and 95 I didnt think of that one.
    And yes I will be using the LM34CAZ so the temperature will be in deg F.
    Yes the LM34 outputs 10mV per deg F that is what I am pumping into the ADC with a Vref so that no conversion is necessary.
    This is a starting point project for myself I have tried this a few time before with no gain. Now that I am using PicBasic it seems to make more sense and I can actually get code to compile (not like in ASM). I have no issues when it comes to hadware but the programming end of it needs alot of work for myself.
    Thanks to all that contributed on this forum and I hope to hear from others soon.
  1. Changing Swordfish code to PBP
    By Ron Marcus in forum mel PIC BASIC Pro
    Last Post: - 29th April 2008, 01:28
  2. Config settings
    By Adrian in forum mel PIC BASIC Pro
    Last Post: - 12th December 2007, 18:24
  3. Changing the Configuration Settings
    By kiwipiper in forum mel PIC BASIC Pro
    Last Post: - 24th October 2007, 07:33
  4. ADCIN - AD settings are wrong
    By teverett in forum mel PIC BASIC Pro
    Last Post: - 4th December 2006, 16:32
  5. Changing 18F WDT postscaler on-the-fly
    Last Post: - 1st August 2006, 21:09
