Try to Compile 18F4550 Macro missing
Results 1 to 8 of 8
    Denicou's Avatar
    Denicou Guest
    Smile
    Thanks Steve......You gave me the right way to think.... Now it's working of course using MPASM as assembler and inhex32.
    Have a good chrismas time Michel
    Bienvenue,
    de tres joyeuses fête a toi aussi.
    Bonne chance!
    Oct 2003
    Australia
    Steve,
    Just trying to compile the usb demo program with MCS and mpasm (Inhex32)
    but get errors caused by the config fuses...
    the errors I get are all the same....
    __CONFIG directives cannot be used with CONFIG directives
    Any idea what these are and how to fix them?
    Cheers
    Squib
    Jan 2007
    you probably checked this, but if you leave the stock __config lines in the 18f4550.inc, the stock 20mhz config fuses will conflict with the specific 4mhz config fuses in USBDemo.bas.
    I just fought with this ******* for like 10 hours, and it turned out to probably have been non-standard USB wire colors! I got frustrated, cut another cable with bizarre colors, and had to figure it out with a meter.. worked first time i hooked up that cable...
    dont trust anything!
    robert.
    Oct 2003
    Australia
    Yeah found some useful info about the config fuses in the FAQ section. LOL
    Already posted elsewhere but anyways. If you don't have v2.47 and you want to disable the MPASM CONFIG deprecated plah plah, make sure your LIST line in the .INC file looks like this...
            LIST p = 18F4550, r = dec, w = -311, w = -230, f = inhx32
    Yeah... all default config lines must be commented as well.
    I still don't understand why there's any default ones anyways...
  1. Fail to compile, COD file missing
    By Jumper in forum mel PIC BASIC Pro
    Last Post: - 29th June 2009, 17:20
  2. Replies: 2
    Last Post: - 10th July 2006, 01:05
  3. Newby- PBP wont compile for 18F (MPLAB)
  4. Compile errors within macro....
    By forgie in forum mel PIC BASIC Pro
    Last Post: - 5th September 2005, 19:08
  5. 18F4550 compile error
    By sean-h in forum USB
    Last Post: - 28th August 2005, 21:27
