Steve,
Here is the complete code (less the data for light patterns)
In this example I've removed the wire from the 10 pot and set SW to the same pin as I have the pot working fine - and it works. If I set SW to RA0, RA2, RA3 etc the LEDs run through each pattern from 1 - 7 in a loop.Code:;************* set up PIC ******************** ADCON1=$0F CMCON = 7 ' Digital inputs CCP1CON = 0 ' PWM off TRISA=%11111111 'set PORTA as all input TRISB=%00000000 'set PORTB as all output PORTB=0 PORTA=0 SW1 var PORTA.1 ;pattern selection switch ;************* set up variables *************** Patt var byte [8] ;used to store the sequences Patt[1]=Patt1 Patt[2]=Patt2 Patt[3]=Patt3 Patt[4]=Patt4 Patt[5]=Patt5 Patt[6]=Patt6 Patt[7]=Patt7 C var byte ;used to advance through pattern D var byte ;used for the speed the sequence runs at scale var byte ;used in the POT command Scale = 254 steps var byte ;used for storing the number of steps in a sequence swcount var byte ;used to select the required sequence required swcount=1 ;set for testing only or default sequence ;**************** main program ******************** main: if sw1=0 then swcount=swcount+1 ;check to see if up button pressed, if so add 1 to SWcount pause 60 ;debounce delay If swcount>7 then swcount=1 ;error trap for exceeding max patterns ;Pot PORTA.1,scale,D ;used to read value from 10k pot and set the speed read patt[swcount],steps ;read the first value of the selected patter and place it in the variable steps for C = 1 to steps ;for / next loop READ PATT[SWCOUNT]+ C,PORTB ;reads the step value for selected pattern and send it to PORTB PAUSE 250 ;delay for speed NEXT GOTO MAIN
As you stated, it must be something is the setting of port A for digital. However I will at some point want one pin to be det up to use the A to D conversion as I want to input the line signal from a CD player to get the LEDs to flash / run to music at some stage in the future, all other inputs.
Sorry if it seems so basic, but as the other Steve can vouch for.. I'm very rusty on the PBP coding !
) - I then discoverd PBP and ported the basics over to a 16F628a, but never got around to doing the music side, and was limited by the number of pins so i couldn'l use the LCD.
