DCD command - need some advice
Results 1 to 21 of 21
Threaded View
  1. #12
    May 2006
    Del Rio, TX, USA
    Quote Originally Posted by malc-c
    Ok' I'm working my way through this version using the 16F873A, but I've hit a small issue...
    I have set port A to all inputs...
    the PIC simply ignores any input on RA2, but more confusingly, it runs each pattern once in sequence, ie it cycles through the patterns as if the button is being pressed, so swcount must in some way be changing...
    Pot PORTA.1,scale,D                     ;used to read value from 10k pot and set the speed
    read patt[swcount],steps                ;read the first value of the selected patter and place it in the variable steps
            for C = 1 to steps              ;for / next loop
               READ PATT[SWCOUNT]+ C,PORTB  ;reads the step value for selected pattern and send it to PORTB
               PAUSE D                      ;delay for speed
            NEXT
    GOTO MAIN
    Exactly what value have you put into ADCON1 to "set port A to all inputs" yet still get the Pot command to work? It seems as though you still might have some of them set as Analog Inputs.
    SteveB
  1. Need "PIC16F84A" Controler schematic Advice...
    By Kyo_89 in forum Schematics
    Last Post: - 28th May 2009, 00:03
  2. Design Advice
    By isaac in forum General
    Last Post: - 12th October 2008, 00:07
  3. Your OTP advice?
    By truvahorse in forum mel PIC BASIC Pro
    Last Post: - 28th June 2008, 17:37
  4. NCD vs. DCD - Commentary
    By andrewroz in forum mel PIC BASIC Pro
    Last Post: - 6th November 2007, 00:16
  5. Advice needed on 'neat' Project!
    By vacpress in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 07:21
