DCD command - need some advice
Results 1 to 21 of 21
    how about this one?
    ;************* set up pattern data **********
    Patt1 DATA 16,1,2,4,8,16,32,64,128,128,64,32,16,8,4,2,1
    Patt2 DATA 8,129,66,36,24,24,36,66,129
    Patt3 DATA 16,1,3,2,6,4,12,8,24,16,48,32,96,64,192,128,0
    Patt4 DATA 16,1,128,2,64,4,32,8,16,8,32,4,64,2,128,1,0
    Patt5 DATA 12,24,60,126,255,231,195,129,0,129,195,231,255
    Patt6 DATA 13,1,2,4,8,17,34,68,136,16,32,64,128,0
    Patt7 DATA 8,128,64,32,16,8,4,2,1
    ;************* set up PIC ********************
    ADCON1=$0F
    CMCON = 7                        ' Digital inputs
    CCP1CON = 0                      ' PWM off
    TRISA=%11100111                  'set PORTA as all input apart from A3 & A4
    TRISB=%00000000                  'set PORTB as all output
    PORTB=0
    ;************* set up variables ***************
    Patt    var byte [8]
    asm
        MOVE?CB _Patt1,_Patt+1 ; Patt[1]
        MOVE?CB _Patt2,_Patt+2 ; Patt[2]
        MOVE?CB _Patt3,_Patt+3 ; Patt[3]
        MOVE?CB _Patt4,_Patt+4 ; Patt[4]
        MOVE?CB _Patt5,_Patt+5 ; Patt[5]
        MOVE?CB _Patt6,_Patt+6 ; Patt[6]
        MOVE?CB _Patt7,_Patt+7 ; Patt[7]
    endasm
    ByteA   var byte
    D var byte
    scale var byte                      ;used in the POT command
    Scale = 254
    steps var byte
    swcount var byte
    swcount=7                           ; set to 3 for testing only
    D=250
    ;**************** main program ********************
        for swcount=1 to 7
            read patt[swcount],steps
            for bytea=1 to steps
               READ PATT[SWCOUNT]+BYTEA,PORTB
               PAUSE D
               NEXT
            next
        GOTO MAIN
    noticed that i skiped the POT command but use a fixed 250mSec delay. It's working here. if you want to use DCD, you'll need to modify the DATA lines and use bit# instead of Decimal value. No big deal
    It shouldn't be different from one to another. DATA remain DATA. PORTB remain PORTB. Well i can't explain why if it doesn't create the expected results with the above suggestion
    Too bad, MPASM text substitution doesn't seems to work with Bytes variable in the #V(Variable) area.. it would be too convenient...
    EDIT: Note that MOVE?CB _Patt1,_Patt+1 can be replace by Patt[1]=Patt1 etc...
    The whole MOVE?CB block (or Patt[x]=Pattx) could also be replace using MPASM text substitution like this
    asm
        local a=1
        while a<7
            MOVE?CB _Patt#v(a),_Patt+a
    a+=1
            endw
    endasm
    malc-c's Avatar
    malc-c Guest
    Quote Originally Posted by mister_e
    how about this one?
    Yup - works a treat here too... the LEDs are cycling through all the pattern sequences quite nicely
    Now sorry to be a pain in the a$$, but you lost me right at the point you went asm
    I assume that this could be done in PBP without dropping out to assembly code, hence the Note that MOVE?CB _Patt1,_Patt+1 can be replace by Patt[1]=Patt1 etc... statement ????
    Sorry if this seems dumb questions, but now that 'm moving away from the simple basic commands and the fact I was (and still am) a bit rusty with my coding, all help to expand the learning curve with PBP is greatly apreciated
    So, i think i lost you pretty much more with the second asm code using the text substitution?
    Sorry sometimes i'm getting sick with those MOVE?CB, PAUSE?C, macro and whatever else... It's the Darrel's fault!
    Yup indeed the whole MOVE?CB ... block could be replace by using...
    Patt[1]=Patt1
    Patt[2]=Patt2
    Patt[3]=Patt3
    Patt[4]=Patt4
    Patt[5]=Patt5
    Patt[6]=Patt6
    Patt[7]=Patt7
    Now compile those line and open the .asm file... you'll discover somewhere those lines...
    ; C:\PBP_PROG\A.BAS        	00040	Patt[1]=Patt1
    	MOVE?CB	_Patt1, _Patt + 00001h
    ; C:\PBP_PROG\A.BAS        	00041	Patt[2]=Patt2
    	MOVE?CB	_Patt2, _Patt + 00002h
    ; C:\PBP_PROG\A.BAS        	00042	Patt[3]=Patt3
    	MOVE?CB	_Patt3, _Patt + 00003h
    ; C:\PBP_PROG\A.BAS        	00043	Patt[4]=Patt4
    	MOVE?CB	_Patt4, _Patt + 00004h
    ; C:\PBP_PROG\A.BAS        	00044	Patt[5]=Patt5
    	MOVE?CB	_Patt5, _Patt + 00005h
    ; C:\PBP_PROG\A.BAS        	00045	Patt[6]=Patt6
    	MOVE?CB	_Patt6, _Patt + 00006h
    ; C:\PBP_PROG\A.BAS        	00046	Patt[7]=Patt7
    	MOVE?CB	_Patt7, _Patt + 00007h
    Interesting eh?
    NOW, why i use the MOVE?CB first? Well didn't thought Patt[1]=Patt1 would worked... later i decide to try and... Woohhooo
    So this is why i edited my previous post. I'm still learning as well. I guess we never stop anyways!
    MOVE?CB: Is a PBP macro wich copy a Constant value to a Byte variable. Not much.
    Glad to hear it's working as expected
    Have fun!
    malc-c's Avatar
    malc-c Guest
    Default An apple for my teacher :)
    Thanks for the explanation...
    May 2006
    Del Rio, TX, USA
    Thumbs up
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1273&stc=1&d=116630151 9">
    Bravo Steve!
    Nice explaination.
    SteveB
    Default Woooho!
    Gracias, Merci, thank you,falemnderit, σασ ευχαριστώ, danke, grazie, ขอบคุณ, teşekkür ederim ,...,..
    malc-c's Avatar
    malc-c Guest
    You guys crack me up !
    Ok' I'm working my way through this version using the 16F873A, but I've hit a small issue which is so basic I can't see why it responds the way it does (it worked with the 16F628a).
    I have set port A to all inputs and added
    SW1 var PORTA.2                         ;pattern selection switch
    I have a 10k pull up resistor between pin 4 (RA2) and +5v with a tactile switch between pin 4 and GND.
    I've added the code
    if SW1=0 then swcount=swcount+1         ;check to see if up button pressed, if so add 1 to swcount
    pause 60                                ;debounce delay
    If swcount>7 then swcount=1             ;error trap for exceeding max patterns
    So in therory if the switch (sw1) is low then swcount is increased by 1, until it is > than 7 and if so then its swcount is reset to 1. This way the pattern is selected by pressing the switch.
    However in practice, the PIC simply ignores any input on RA2, but more confusingly, it runs each pattern once in sequence, ie it cycles through the patterns as if the button is being pressed, so swcount must in some way be changing as the remainder of the code works if the above lines are remed out and swcount is manual set to 1, 2, 3 etc, which results in just the selected pattern running.
    Pot PORTA.1,scale,D                     ;used to read value from 10k pot and set the speed
    read patt[swcount],steps                ;read the first value of the selected patter and place it in the variable steps
            for C = 1 to steps              ;for / next loop
               READ PATT[SWCOUNT]+ C,PORTB  ;reads the step value for selected pattern and send it to PORTB
               PAUSE D                      ;delay for speed
            NEXT
    GOTO MAIN
    Its probably me having a blonde moment (no offence to any fair haired madiens out there ) - but can anyone shed some light why this isn't working.
  1. Need "PIC16F84A" Controler schematic Advice...
    By Kyo_89 in forum Schematics
    Last Post: - 27th May 2009, 23:03
  2. Design Advice
    By isaac in forum General
    Last Post: - 11th October 2008, 23:07
  3. Your OTP advice?
    By truvahorse in forum mel PIC BASIC Pro
    Last Post: - 28th June 2008, 16:37
  4. NCD vs. DCD - Commentary
    By andrewroz in forum mel PIC BASIC Pro
    Last Post: - 5th November 2007, 23:16
  5. Advice needed on 'neat' Project!
    By vacpress in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 06:21
