DCD command - need some advice
Results 1 to 21 of 21
    i'm not sure what you expect at the output, but when you said PORTB=DCD patt3 worked but you want to use some kind of text substitution, and use something like PORTB=DCD patt[x] and if x=3 work... you'll like the following
    ;************* set up pattern data **********
    Patt1 DATA 16,1,2,4,8,16,32,64,128,128,64,32,16,8,4,2,1
    Patt2 DATA 8,129,66,36,24,24,36,66,129
    Patt3 DATA 16,1,3,2,6,4,12,8,24,16,48,32,96,64,192,128,0
    Patt4 DATA 16,1,128,2,64,4,32,8,16,8,32,4,64,2,128,1,0
    Patt5 DATA 12,24,60,126,255,231,195,129,0,129,195,231,255
    Patt6 DATA 13,1,2,4,8,17,34,68,136,16,32,64,128,0
    Patt7 DATA 8,128,64,32,16,8,4,2,1
    ;************* set up PIC ********************
    ADCON1=$0F
    CMCON = 7                        ' Digital inputs
    CCP1CON = 0                      ' PWM off
    TRISA=%11100111                  'set PORTA as all input apart from A3 & A4
    TRISB=%00000000                  'set PORTB as all output
    PORTB=0
    ;************* set up variables ***************
    Patt    var byte [8]
    asm
        MOVE?CB _Patt1,_Patt+1  ; Patt[1]
        MOVE?CB _Patt2,_Patt+2  ; Patt[2]
        MOVE?CB _Patt3,_Patt+3  ; Patt[3]
        MOVE?CB _Patt4,_Patt+4  ; Patt[4]
        MOVE?CB _Patt5,_Patt+5  ; Patt[5]
        MOVE?CB _Patt6,_Patt+6  ; Patt[6]
        MOVE?CB _Patt7,_Patt+7  ; Patt[7]
    endasm
    ByteB   var byte
    ByteA   var byte
    D var byte
    scale var byte                      ;used in the POT command
    Scale = 254
    steps var byte
    swcount var byte
    swcount=3                           ; set to 3 for testing only
    N var byte
    ;**************** main program ********************
    if swcount = 1 then read Patt1, steps   ;read the first value in data string patt1 and place it in steps
    if swcount = 2 then read Patt2, steps
    If swcount = 3 then read Patt3, steps
    if swcount = 4 then read Patt4, steps
    if swcount = 5 then read Patt5, steps
    If swcount = 6 then read Patt6, steps
    If swcount = 7 then Read patt7, steps
    n = swcount
    Pot PORTA.1,scale,D                 ;used to read value from 10k pot
        FOR ByteA=0 to steps
            PORTB=DCD Patt[n]
            PAUSE D
        NEXT
    PAUSE 500
    GOTO main
    As you see, i didn't touch too much your previous code.. just add some spices in.
    Maybe Darrel or someone else have a better solution?
  1. Need "PIC16F84A" Controler schematic Advice...
    By Kyo_89 in forum Schematics
    Last Post: - 28th May 2009, 00:03
  2. Design Advice
    By isaac in forum General
    Last Post: - 12th October 2008, 00:07
  3. Your OTP advice?
    By truvahorse in forum mel PIC BASIC Pro
    Last Post: - 28th June 2008, 17:37
  4. NCD vs. DCD - Commentary
    By andrewroz in forum mel PIC BASIC Pro
    Last Post: - 6th November 2007, 00:16
  5. Advice needed on 'neat' Project!
    By vacpress in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 07:21
