DCF77 and PICBasic
Results 1 to 2 of 2
    mdogsa's Avatar
    mdogsa Guest
    Default DCF77 and PICBasic
    Hi!
    I'm trying to build a DCF77 decoder with picbasic but i'm having trouble witgh it.
    Has anybody an idea or an code example for a decoder??
    Thank you
    ActiveHouse's Avatar
    ActiveHouse Guest
    Default I have some working code
    I just wrote some well-documented code, which simply
    decodes DCF77 data and displays it on a standard
    alphanumeric LCD (4-bit mode).
    Every minute, it updates the display, and even the seconds
    are updating every second (based on the start of a new pulse, every second)
    It's been running since 4 pm, and it's now passed 10 pm, without any error seen on my screen ;-)
    The code is about 270 lines, but I did left a lot of white lines
    in between different procedures etc ...
    I also did add a lot of comment ...
    (Everything does fit in less then 1K of memory)
    Please note that this is my first code I ever did write in PBP.
    Best regards,
    Kris
