Fast Loop in PICBASIC Pro
Results 1 to 12 of 12
    Quote Originally Posted by Bonaparte
    Hi guys,
    I'm new to PICBasic!! I'm programming PIC16F877A using PICBASIC Pro & MicroStudio...
    What's the FASTEST way to implement a simple loop with a loop counter (initially positive) which decrements & stops when it reaches zero...
    Again, i'm talking about the FASTEST (in decrementing counter & repeating itself) way?!!!
    Thx...
    LOOP: For I=10 TO 1 STEP -1:NEXT I:GOTO LOOP
    That's not so hard now is it? It's just like in the PBP manual, with a couple of very small changes.
    Jan 2006
    Istanbul
    There are ten cars in front of you.
    And someone is asking which one is the fastest.
    Then you look at each one and say "that one".
    But the fastest car you found is the fastest car among the ones in front of you.
    There are other fastest cars around.
    Now, "fastest" changes from one perspective to another.
    The fastest for you may be the slowest for me.
    Take Skimask's example:
    if you run this with 4mhz, you get the "fastest" loop.
    If you run the same loop at 20Mhz, you get the "fastest", too, but faster then
    4mhz.
    If you run it at 40Mhz, you still get "fastest" but faster then 20Mhz.
    Now, you do the math.
    I VAR BYTE SYSTEM
    LOOP1: ; 150 cycles. Not very fast
        NEXT I
    LOOP2: ; 90 cycles. A lot better
        I = 10
        REPEAT
         I=I-1
        UNTIL I=0
    ASM   ; 31 cycles. Pretty fast
    LOOP3
         MOVLW 0xA
         MOVWF I      ; I=10
    INNER
         DECFSZ I,F   ; I=I-1. IF I=0 skip next instruction
         GOTO INNER  ; Loop until I=0
    FINISH:
        GOTO FINISH
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jan 2006
    Istanbul
    Quote Originally Posted by Bruce
     I VAR BYTE SYSTEM
        NEXT I
        I = 10
        REPEAT
         I=I-1
        UNTIL I=0
    LOOP3
         MOVLW 0xA
         MOVWF I      ; I=10
    INNER
    FINISH:
        GOTO FINISH
    ...and, there is also the expert approach!
    You know, we kiss the hand of the experts here.
    Quote Originally Posted by sayzer
    Or the keyboard of the experts...
    However, I saw the original poster's first line
    Hi guys,
    which says to me 'not fluent in any sort of asm', so he's probably not going to get much better than 90 cycles
    JDG
    Bonaparte's Avatar
    Bonaparte Guest
    I VAR BYTE SYSTEM
        NEXT I
        I = 10
        REPEAT
         I=I-1
        UNTIL I=0
    LOOP3
         MOVLW 0xA
         MOVWF I      ; I=10
    INNER
    FINISH:
        GOTO FINISH
    I will probably go for Loop 2 implementation..
    (Assembly isn't an appealing choice!!)
    However, is there any way to estimate the time required to implement this Loop (2). I need to calculate the time needed to decrement the counter, compare its current value to the end value & the repetition (go back to start of loop) of the body time...
    I'm using a 20 MHz crystal as clock....
    if it can't be estimated from BASIC code... can the .asm file generated by compiler in assembly help me estimate delay time in executing loop knowing the time for each assembly line code???
    This is what i'm trying to do; generation of 40kHz pulses (25us)
    Loop:
    counter = 16
    (set one o/p pin high
    pause (delay) by 11 us
    set o/p pin to low (zero)
    puse (delay) by 10 us
    decrement counter & compare it
    repeat loop again
    i need the total time of loop to be 25 microseconds....
    HELP PLEASE!!!
    Why not using the internal PWM module instead? it will run in background and you don't need to care about latency etc etc.
    use something like this...
    DEFINE OSC 20
    TRISC=0
    duty var word
    duty = 250                                  ' duty value for 50% duty cycle
    PR2 = 124                                   ' period for 40KHZ
    T2CON = %00000100                           ' timer2 on, prescale 1:1
    CCPR1L = duty>>2                            ' eight MSB of duty cycle value
    CCP1CON = (duty.lowbyte&3)<<5 | %00001100   ' store  2 LSB of duty
                                                '  & set PWM mode
    START:
          PAUSE 1
          GOTO START
    and look what happen on PORTC.2 pin.
    Need to start it and stop it ? here's something using PORTB.0 as trigger source
    DEFINE OSC 20
    TRISC=0
    duty        var word
    PWMMode     var byte
    StartStop   var bit
    PWMMode = (duty.lowbyte&3)<<5 | %00001100   ' store  2 LSB of duty
                                                '    & set PWM mode
    START:
        IF PORTB.0=0 then            '
            startstop=startstop ^ 1  ' toggle between start/stop
            if startstop=1 then      '
                CCP1CON=PWMMODE      ' Start PWM
                ELSE                 '
                    CCP1CON=0        ' Stop PWM
                    PORTC.2=0        ' make sure the pin is low
                ENDIF                '
            WHILE PORTB.0=0 : WEND   ' wait until trigger release
            PAUSE 100                ' debounce delay
        GOTO START
    How to calculate those value easy? PicMultiCalc software available bellow for FREE
    http://mister-e.org/pages/utilitiespag.html
    ScreenShot
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1280&stc=1&d=116639098 4">
    HTH
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    I agree with Steve (and everyone else) that the hardware PWM sounds best for what you described. But, if it will not work for you consider "unrolling" your loops like that shown below. You lose no time in looping but it does cost you more code space (16 repeats is not huge considering the amount of memory in the 877A).
    DEFINE OSC 20
    TRISB.0 = 0
    PORTB = 0
    PORTB.0 = 1   ' I = 1 (on for 12.6 uS)
    @ nop
    Pauseus 12
    PORTB.0 = 0   ' (off for 12.4 uS)
    PAUSEUS 12
    PORTB.0 = 1   ' I = 2
    @ nop
    Pauseus 12
    PORTB.0 = 0
    PAUSEUS 12
    ;(more of the same here)
    PORTB.0 = 1   ' I = 16
    @ nop
    Pauseus 12
    PORTB.0 = 0
    PAUSEUS 12
    Endhere:
    goto Endhere
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    could be...
    DEFINE OSC 20
    TRISB.0 = 0
    PORTB = 0
    pauseus 0 ' do nothing good but include PAUSEUS?C macro
    TRISB.0 = 0
    PORTB = 0
    start:
    asm
        CHK?RP PORTB
        local a=0
        while a<16
            BSF PORTB,0
            nop
            PAUSEUS?C 12
            BCF PORTB,0
            nop
            PAUSEUS?C 12
    a+=1
        endw
    endasm
    goto start
    now play with the a < x value, and look what happen to your code size.. interesting eh?
    Now compare the code size of
    PORTB.0 = 1
    @ nop
    Pauseus 12
    PORTB.0 = 0
    @ nop
    PAUSEUS 12
    copy and pasted 16 times, with the one generated with my solution... mmm interesting
    Sometime MPASM directive are really handy!
    EDIT: you could also use
    @   local a=0
    @   while a<16
            PORTB.0=1
            @ nop
            PAUSEUS 12
            PORTB.0=0
            @ nop
            PAUSEUS 12
    @a+=1
    @       endw
    If you don't like the PAUSE?C, BSF, BCF option... both generate the same code.
  1. Controlsystem for compact sporting (clay shooting)
    By Fredrick in forum mel PIC BASIC Pro
    Last Post: - 30th July 2009, 16:48
  2. Serial Relays
    By tazntex in forum General
    Last Post: - 17th May 2007, 17:42
    Last Post: - 15th April 2007, 18:31
  4. Question for all that use MELABS PICBASIC PRO
    By oskuro in forum Off Topic
    Last Post: - 24th March 2005, 17:15
  5. PicBasic Pro & PicBasic syntax different
    By Billyc in forum General
    Last Post: - 16th April 2004, 21:19
