Why not using the internal PWM module instead?  it will run in background and you don't need to care about latency etc etc.
use something like this...
	DEFINE OSC 20
TRISC=0
duty var word
duty = 250                                  ' duty value for 50% duty cycle
PR2 = 124                                   ' period for 40KHZ
T2CON = %00000100                           ' timer2 on, prescale 1:1
CCPR1L = duty>>2                            ' eight MSB of duty cycle value
CCP1CON = (duty.lowbyte&3)<<5 | %00001100   ' store  2 LSB of duty
                                            '  & set PWM mode
START:
      PAUSE 1
      GOTO START
 and look what happen on PORTC.2 pin.
Need to start it and stop it ?  here's something using PORTB.0 as trigger source
	DEFINE OSC 20
TRISC=0
duty        var word
PWMMode     var byte
StartStop   var bit
PWMMode = (duty.lowbyte&3)<<5 | %00001100   ' store  2 LSB of duty
                                            '    & set PWM mode
START:
    IF PORTB.0=0 then            '
        startstop=startstop ^ 1  ' toggle between start/stop
        if startstop=1 then      '
            CCP1CON=PWMMODE      ' Start PWM
            ELSE                 '
                CCP1CON=0        ' Stop PWM
                PORTC.2=0        ' make sure the pin is low
            ENDIF                '
        WHILE PORTB.0=0 : WEND   ' wait until trigger release
        PAUSE 100                ' debounce delay
    GOTO START
 How to calculate those value easy?  PicMultiCalc software available bellow for FREE
http://mister-e.org/pages/utilitiespag.html
ScreenShot
<img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1280&stc=1&d=116639098  4">
HTH
