Switch LCD OFF during sleep, possible?
Results 1 to 11 of 11
    SWITZERLAND (french speaking)
    Default Switch LCD OFF during sleep, possible?
    Hello,
    I'm using a 16F88 and an LCD display.
    Is it possible to switch OFF the LCD display during sleep mode to drop the power consumption even more?
    If yes, how?
    Roger
    Default All things possible
    Hi Roger,
    sure it's possible, just power your LCD from a pic pin, you might have to use a switching transistor, and you might not. How much current does your display draw when in full display minus backlight, and how much does it draw when all blank? It may not be worth the effort, I have seen LCDs powered by very small batteries for very extended times.
    JS
    Talking Inverted logic ...
    Quote Originally Posted by flotulopex
    Hello,
    If yes, how?
    Just apply Power through a Pic PIN when NOT asleep ... and think to change the pin level BEFORE entering sleep !!!
    La Pallice book 34, chapter 9,10 and 11 !!!
    Default ... was to simple for me!
    Okay,
    I should have think about such a simple solution...
    "La Pallice", do you mean the Compiler's Manual?
    Thank you.
    Roger
    Okay,
    Thank you.
    No,Flotul ...
    The man who wrote around year 1700 ... , between others: " a quarter before he died, he was still alive ..."
    Feb 2005
    Kolkata-India
    Default Make sure you clear the flag
    If you are powering your LCD you need to re-initialize the LCD. PBP would do that for you when it encounters the next LCDOUT instruction. All you need to do is
    FLAGS=0
    This will guide PBP LCD library that the LCD has not yet been initialized.
    Sougata
    Default Flag?
    I don't understand.
    If you are powering your LCD...
    Do you mean this if I power the LCD through a PIC's Pin ?
    Shall I set FLAG=0 when I come back from sleep mode?
    Roger
  1. Play with LCD on PICDEM
  2. 18F1220 LCD and Sleep
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 13th July 2008, 18:58
  3. Need help with SLEEP mode
    By aggie007 in forum mel PIC BASIC Pro
    Last Post: - 28th November 2007, 09:56
  5. Wierd sleep issue
    By orca in forum mel PIC BASIC Pro
    Last Post: - 14th March 2006, 22:06
