If you're using a Bootloader, be sure you place the following line at the top of your code
DEFINE LOADER_USED 1
if it doesn't work, post your whole code here, and tell us your PIC #, OSC speed, AND config fuses list you set when you loaded your bootloader firmware in your PIC.
One thing is sure, your LCD is not initialised properly.
