Olympic timer Scroll Text
Results 1 to 9 of 9
    Patrick's Avatar
    Patrick Guest
    Talking Scroll
    Thanks a mil
    I will try to get it working
    Patrick
    Patrick's Avatar
    Patrick Guest
    Unhappy Scroll text
    I have tried it an get similar behaviour to the orig program
    Im using a bootloader,can his have influance as it might occupy the Data codespace
    Im now more determant to get to the bottom of this
    See include photo
    If you're using a Bootloader, be sure you place the following line at the top of your code
    DEFINE LOADER_USED 1
    if it doesn't work, post your whole code here, and tell us your PIC #, OSC speed, AND config fuses list you set when you loaded your bootloader firmware in your PIC.
    One thing is sure, your LCD is not initialised properly.
    Patrick's Avatar
    Patrick Guest
    Red face Scroll Text
    The code is as posted by flotulopex with the next as top of file:
    @ DEVICE pic16F876, XT_OSC ' System Clock Options
    @ DEVICE pic16F876, WDT_ON ' Watchdog Timer
    @ DEVICE pic16F876, PWRT_ON ' Power-On Timer
    @ DEVICE pic16F876, BOD_ON ' Brown-Out Detect
    @ DEVICE pic16F876, LVP_OFF ' Low-Voltage Programming
    @ DEVICE pic16F876, CPD_OFF ' Data Memory Code Protect
    @ DEVICE pic16F876, PROTECT_OFF
    ' Program Code Protection
    @ DEVICE pic16F876, WRT_OFF ' Flash Memory Word Enable
    DEFINE LOADER_USED 1 ' If using bootloader to program pic
    DEFINE LCD_DREG PORTC 'Define PIC port used for LCD Data lines
    DEFINE LCD_DBIT 0 'Define first pin of portc connected to LCD DC4
    DEFINE LCD_RSREG PORTC 'Define PIC port used for RS line of LCD
    DEFINE LCD_RSBIT 4 'Define Portc pin used for RS connection
    DEFINE LCD_EREG PORTC 'Define PIC port used for E line of LCD
    DEFINE LCD_EBIT 5 'Define PortC pin used for E connection
    DEFINE LCD_BITS 4 'Define the 4 bit communication mode to LCD
    DEFINE LCD_LINES 2 'Define using a 2 line LCD
    DEFINE LCD_COMMANDUS 2000 'Define delay time between sending LCD commands
    DEFINE LCD_DATAUS 50 'Define delay time between data sent.
    Feb 2005
    Kolkata-India
    Talking Try this out
    If you can get your lcd to respond atleast then please tryout the following code. You will be surprised.
    I post a little program here and would like you guys to try it out U N-E D I T E D. Please use the LCD Defines as your config. You can use a 16/20 characters display if you wish. Steve would you mind explaining I am a little too drunk.
    MAIN:
    LCDOUT $FE,1
    LCDOUT "MERRY CHRISTMAS AND HAPPY NEW YEAR 2007 "
    LCDOUT $FE,$C0
    LCDOUT "***FROM YOUR FRIEND SOUGATA IN INDIA****"
    PAUSE 1000
    LOOP:
    LCDOUT $FE, $18
    PAUSE 500
    GOTO LOOP
    Sougata
    SWITZERLAND (french speaking)
    Default Cool!
    Wow! Well done.
    In the "LOOP:", let's go the other way: "LCDOUT $FE, $1C" - from the LEFT to the Right.
    Roger
    LMAO! Well even drunk you got it Take one of those...
    Well explanation is easy, but i will make it simple and skip some information.
    LCDOUT $FE,1
    LCDOUT $FE,$C0
    There you fill the LCD memory/buffer...plahplahplah
    LOOP:
    LCDOUT $FE, $18
    PAUSE 500
    GOTO LOOP
    For this one, open a HD44780 LCD datasheet, and find the 'Cursor or display shift' Register. Now, read the S/C bit information. You don't like the way it move, set the R/L bit.
    EDIT: Yup Flotulopex, you got it!
  1. About olympic timer..
    By Eng4444 in forum mel PIC BASIC Pro
    Last Post: - 4th June 2006, 10:16
  2. Melanie's Olympic Timer
    By nedtron in forum mel PIC BASIC Pro
    Last Post: - 11th January 2006, 15:41
  3. Olympic Timer MPH readout
    Last Post: - 19th August 2005, 18:56
  4. Help with scroll text in Melanie Olympic Timer
    By jorge in forum mel PIC BASIC Pro
    Last Post: - 9th November 2004, 15:52
  5. Melanie Olympic Timer -> Banner....scroll text...
    Last Post: - 8th November 2004, 23:11
